Seems nice enough :) . Almost the same stepping that I'm going to buy: LDBFE 0626GPMW. Keep us updated :fact:Quote:
which vcore you guys reporting, the one in bios or cpu-z ?
update : 2600 2h prime stable at 1.36v....
update 2 : 2650 prime stable 2h 1.36v ;)
Having some fun her
http://valid.x86-secret.com/show_oc?id=117133
more to come
Here is mine :
4000+ AM2 Windsor : 3000Mhz stable :) Vcore = 1,55V
and WR @ 3147Mhz :
http://valid.x86-secret.com/show_oc.php?id=118140
Mobo : M59SLI-S5
:D Happy here in france !
Here is mine,
http://fabian.bricard.net/images/3800.jpg
255x10 @ 1.31v (default) w/ XP90
Will give it a day or two before cranking in the volts.
Hi
This is my first overclocking at my new DFI board
I hope this isn't bad
http://members.inode.at/s.amidzic/DFI2.jpg
any reason you're running a 9x multi?Quote:
Originally Posted by Dede99
The reason is that it stay's stable at 9 the board wan't let me go up at multi at 10
How do I get the black windows taskbar?
Any stepping info?Quote:
Are you also aware that board shows the wrong VCore readings? More info here.
Just thought I would make you aware to reduce the likeliness of a blown cpu as I also own the same board on another system.
Looking good though :)
i hope this help's
http://members.inode.at/s.amidzic/DFI002.jpg
Here's mine. AMD 3800+ X2, LDBFE 0609XPMW. Running on AIR, using Zalman CNPS7000B-Cu. Running 2.8Ghz on VCore @ 1.44v with 2GB Memory @ CL2.5-3-3-6, 1:1, 2T (4 x 512Mb GSkill + Patriot-TCCD) RAMs.
- CPU-Z
- SuperPi 32M in various stages:
http://img84.imageshack.us/img84/669...hz01ve2.th.jpg http://img85.imageshack.us/img85/102...hz03gy8.th.jpg
http://img154.imageshack.us/img154/9...hz04bv6.th.jpg http://img146.imageshack.us/img146/5...zfindr5.th.jpg
Originally Posted by dave_graham
just got 2 3800+ X@ from dave few hours ago
installed mine and booted up with teh settings in the screenshot below :woot:
it is
ADA3800AA5CD
LCBIE 0619RPMW
volt in bois 1.35v
http://img174.imageshack.us/img174/9437/2pj3.jpg
AMD X2 3800 LDBFE 0608RPMW @2600MHz 1.5V using XP-120 - 260x10 2.5-3-4 OCZ Platinum.
Oscar
This is my first OC, and here is what I got. I have my X2 3800+ running at 2.6ghz with 1.45v and HT 4x, idle temps of 31C-33C and max temps at 44C-45C, using a Thermaltake Big Typhoon. Still trying for 2.7ghz stable.
Just hit 2.7ghz, it is topping out at 53C-54C at full load. Is that a decent OC? 700mhz at just over stock temps?
EDIT: AAAARRGGGHHH!!!! My PC froze! 2.7ghz is not stable for me, looks like 2.6ghz is my limit.
I have mine to @2.7GHz to 1.55V.
Oscar
I had mine at 1.45v @ 2.7ghz, do you think upping the voltage might help make it more stable? It was at 54C, so I can't do too much more with it, but do you think upping it from 1.45v to like 1.5v would make it stable?
Of course! My X2 is fully stable 10h primer95 stable. ;)Quote:
Oscar
I'm at 2.5 Ghz 1.328v (board undervolts from stock 1.35v)
X2 3800+ Manchester
LDBFE 0621 GPMW
Running 260x10 @ stock volt(cpu-z 1.31vcore)
Noctua NH-U9 with Zalman 92mm 53cfm@7v Idle 27-28 Load both cores 38-39
Prime stable, but fails to load win @ 270x10. Havnt tested it more than that, Im in the middle of moving :D
Ok, so you think that if I up the voltage from 1.45v up to 1.50v it will be stable? I will try that out later today. If I can get a 700mhz OC that would be great. As of now I am already at the levels of an X2 5000+, so I am already saving like $350 just from overclocking. If I can get 2.7ghz and still stay at under 55C that would be sweet.
Although at 2.7ghz @ 1.45v it was hovering around 54C when it crashed, but it was running for about 30min-1 hour so I might be able to keep it arouind 55C if I put it at 1.50v. And just for the record these temps are using speedfan, but from what I've heard speedfan is very accurate. Ok, I have it at 2.7ghz, 1.50v, and HT 4x. Lets see how hot it gets.
Ah man, I am not liking this. It is at 57C and rising. Is that something to worry about? I heard that 60C is the absolute limit, is that true?
Your computer will shut down if the cpu gets to hot, AMD has a built in security. BUT I would think about all my other settings before raising the voltages on cpu more, cause at 1.55 there are reported deaths, so unless you have phasecooling or waterchilling, I suggest that you lower it to 1.525 or lower. I'm able to run my x2 3800+ at 2.85ghz at 1.45 volts, so you understand why I think your volt is high? :) Lower the HT to 3X, Set the ram divider to 166/333, and cpu multi to 9x and you can push your cpu higher if your motherboard is up to it. Mine is stable even over HTT 300..... last overclock I had stable was this.... :Quote:
Originally Posted by Brutus013
CPU 2.75 GHZ, RAM 500 MHZ, HTT 305(!!)MHZ (You may now HTT as FSB, but AMD has HTT, NOT FSB), and then all settings was set like above here again. Good luck! :banana:
