my leadtek 6800LE just came today! can't wait to get home from work and play with it :banana:
This is terribly upseting...Quote:
Originally Posted by Susquehannock
I've successfully unlocked all pipes 16 x 1, 6vp and It 'appears' to be working fine... no artifacts whatsoever are noticealbe in 3dmark01, 03 and 05...
I benched the card staight out of the box on my system, results:
after unlocking the pipesQuote:
01 - 17037
03 - 6879
05 - 2670
but when I tried to OC it with the pipes open I can't OC the card at all??Quote:
01 - 18533
03 - 9185
05 - 3750
does this mean my card is bad? :shrug:
I'm using the 71.89 leadtek drivers that came with the card, could that have anything to do with it?
EDIT:
OK, I followed the above advice and the advice of Don Vercetti
and Now I can OC with 16 x 1, 6vp... resultsQuote:
ah if the pipes dont allow OC in rivatuner, or whatever you use, then this means they are bad, but they might not be noticeably so.
You have two options;
(1) Use Winfox to overclock.
(2) This is the better way. In rivatuner, go to the Power User tab. Then, in the list below, select "Rivatuner RC 16.5/Nvidia/Overclocking" and open it. In "DisableInternalClockTest" make it a 1, and you should have no trouble OC'ing.
So apparently it IS overclocking, and having results, and I'm not 'seeing' any noticeable Artifacts in 3dmark05 with my OC's... and haven't seen any artifacts at all since I put this card in...Quote:
350/700
3dmark05 - 4205
OC 350/800
3dmark05 - 4436
this is all just preliminary, I just put the card in the computer about 2 hours ago, I haven't tried to push for a great OC, just checked to see if it can be done...
I'm gonna play SW: Republic Commando for a little bit, and maybe Doom 3 and see how the new card does, check for any arties...
:fact: http://service.futuremark.com/compare?2k3=4213513
Not to shabby for nforceII.Will try for higher mem.I c a lot of people running 970. :slobber:
Yup, my memory runs at 930 on stock cooling and voltages.
I've bumped the voltage now from 2.7V to 2.8V and now it can go to about 940 while remaining perfectly stable (some artifacting at 950). I'll probably think about trying 2.9V later =)
As soon as I do the capacitor mod and increase the voltages I hope I'll be able to get 1GHz in the memory for full 6800GT creamy goodness.
yeah, I'm runing 386 / 915 stock cooling and voltage...Quote:
Originally Posted by ChronoReverse
but how do I bump up the voltage? I open winfox and it's not enabled? do I need to use Nibitor? any guides on how to do it?
Yeah, you have to use Nibitor for this.
Read this guide.
Thx for the guide!
Ok, looks like my Memory was maxing out around 900 even if I bumped up the volts, but I did use NibiTor to edit my BIOS to get 1.4v which allowed my GPU to clock up to 441.
I slpapped a couple of fans on the card to keep it cool, see the pics below, this dropped my idle temps by 10 C and load temp by a little more than 10 C...
http://www.ocforums.com/attachment.p...id=44458&stc=1
http://www.ocforums.com/attachment.p...id=44459&stc=1
http://www.ocforums.com/attachment.p...id=44460&stc=1
Final Results:
AGP bus 82
16 x 1 / 6vp GPU 441/ Mem 909
3dmark05 - 5239
3dmark03 - 12214
3dmark01 - 20105
http://www.ocforums.com/attachment.p...id=44457&stc=1
Did you actually do the physical volt mod for the memory? You can't change the voltage via bios for the ram
why do you put a fan on the backside ? it's cools nothing.. it's just for the beauty of it.
If that were true it wouldn't get warm... :stick:Quote:
Originally Posted by Suffocation
and for your next question, with 1.4v load temp was 63 before, 53 after.
but I alreeady had that fan in my case cooling the video card from the side, but with this card it wasn't getting any airflow from the way it was positioned, I figured, just slap it on the back end. works great :toast:
Uh.. no.. lol... I was actually wondering about that... I was thinking the volts had nothing to do with the Vram cuz I couldn't get anymore out of it... that makes sense...Quote:
oh well, I happy.... for now :rolleyes: I don't plan on doing any hard mods, I'm plenty happy with my clocks and am looking forward to actually playing game on my computer for once.... just getting over my 4 month overclocking / modding binge..
My ledtek 6800LE unlocked to 16x6 and i reached 490 on the core and 976 on the mem with the vgpu mod at 1.66v. Here is the compare url: http://service.futuremark.com/compare?2k1=8700527.
I did this using my friends athlon64 as i still have an athlonxp.
Hi everyone, first time poster long time lurker... Thanks to everyone who contributed advice to this thread.
My Leadtek was unlocked and overclocked previously, but from the links in this thread I managed to get the guts to do the volt mod. 1.4V, core now at 450 (at 460 it would freeze 3DMk03 during Nature) and 930 mem. 12840 points and hoping to reach 13k with a few more tweaks or a lucky run.
Cooling still stock, I'm getting a 5-6 deg temp increase since 1.4V.
:welcome: :wave: Welcome to XS!Quote:
Originally Posted by Onyx_6800LE
increasing your cpu a little would probably get you those extra points (thank you, gt1).
Hi guys, first time posting in this forum and want to share my experience with the Leadtek 6800LE. Got it from NE a couple of weeks ago and successfully unlocked to 16/6, I also modded the original firmware for 1.4v 405/900 w/o problems.
My concern now is that I can't reach some good numbers with 3DMark as other people in this thread, specially '05:
01 = 20,097
03 = 12,537
05 = 4,441
System Specs:
Gigabyte GA-8iPE1000-Pro v2
Intel P4 3.0E Ghz Overclocked to 3.75Ghz(250mhz x 15)
520W Super Flower Power Supply
Antec PlusView Tower Case
2 x 512MB PC3200 Corsair RAM (Dual Channel @ 333Mhz)
2 x 160GB Seagate HDs
Pioneer DVR-107
Soundblaster Audigy 2 ZS
Leadtek 6800LE (Latest Nvidia drivers 77.77)
Windows XP-Pro SP2 (All updates installed)
Originally Posted by jsquare
Maybe I'm totally offbase here... but wtf is your RAM doing at DDR 333 when your clock speed is 250... your RAM should be pushing DDR 500.... looks to me like the RAM is bottlenecing your system...
I'm an AMD user though, don't know much about Intel Overclocking.... but it was my understanding that intel systems are more dependent on bandwidth, where as AMD more affected by timings...
My RAM won't go that high(500Mhz) specially when the CPU is also overclocked, but I tried @ FSB 241Mhz in which the BIOS sets the memory at 400Mhz and CPU 3.61Ghz and my '05 score increased to 4,662(not enought).
One thing that still bothers me is this settings that shows AGP @ 2X under OS, I searched fo a solution but I can't find an answer for it.
http://www.xtremesystems.org/forums/...id=36461&stc=1
The scores you got are higher than mine so be happy, most of the scores you see are kill shots with artifacts when from the general idea of your post you want a 24/7 setting. Try looking around in the driver settings for the OS probelm. Also check to see if you bios has a force to 8x setting for the agp slot my abit nf7-s did.Quote:
your 01 and 03 scores are perfectly decent, and 05 isn't really low. At 440/980 i got 5500, and yours is clocked a lot slower than mine, so i guess thats reasonble.
Yeah I know that some of my '01 & '03 scores are actually higher than those listed at Tom's VGA Charts IV '03 vs ATI X800 XT PE, and almost match 6800GT's Chart VII '05 scores, but I had an Leadtek 6800 GT (OC to Ultra speeds) that scored ~5,700 in '05 and I was hoping that this LE could reach ~5,000 with 16/6 and bit of overclocking.
The AGP@2X still an issue that worries me and it may be driver(nVidia or Intel) related since my other 8X card(PNY 6200) on another system(Dell 400SC) reads the same thing, BIOS are set at Auto(8X) in both systems and my old Ti4200 4X card is recognized as 4x not 2x by the OS.
Not mine, NO artifacts, I only post scores with no artifacts, the speed I run at... people posting benchies with artifacts are cheating :nono:Quote:
Originally Posted by total_assault
Yeah, defineately fix the 2x AGP issue...Quote:
but I still think if you had better RAM, capable of DDR 500, you'd see a HUGE jump in your scores... not to mention your system would run better and faster.
I may try to get some PC4000 or PC4200 and see how far it goes, but can't find a solution to the 2x problem.Quote:
Originally Posted by Darien
Did you managed to unlock all 16/6 via BIOS mod instead of RivaTuner?, is there a chance that I could get a copy of that custom BIOS for the 6800LE that you list under your Signature?
Thanks!
Re: disable internal clock test
WRONG! Numerous people have reported the "bug" that rivatuner has that prevents overclockings... afterall users report no artifacts when going higher. Fools paradise. The errors are there. They may not manifest themselves as visible artifcats because they alter values only slightly or are not used for pixel output value.Quote:
"In rivatuner, go to the Power User tab. Then, in the list below, select "Rivatuner RC 16.5/Nvidia/Overclocking" and open it. In "DisableInternalClockTest" make it a 1, and you should have no trouble OC'ing.
The internal clock test definetly works... maybe even not agressively enough (in short time period cant detect long term stability problems).
Ofcourse if all you care is higher 3dmarks, by all means disable it. But, through extensive testing I have found that scores decrease before you reach point of artifacts, and then there is stuttering and freezing/locking up issues that I am trying to figure out.
