Download
nvflashv513.exe. Now unzip the contents to a blank formatted floppy disk and also load your original bios (just encase theres something wrong with the new one) and the new edited copy onto it.
Make a bootable floppy for you can get into pure DOS.. If you dont know how just take a blank floppy disk and insert it into the floppy drive. Open up windows explorer and right click on the A drive and select make a bootable disk.
Now boot the computer with the bootable disk installed in the floppy drive. There will be some options that come up on the screen asking you if you want to boot into windows ect..ect.. Choose the one that says command prompt.
Now put in the other floppy disk with the nvflash and your original and edited bios.. Type nvflash.exe -5 -6 "name of the bios file .rom" and hit enter.
It will search for the card and when it finds one it will ask you if you want to flash this card and hit "y" i think or enter for yes.. Reboot without the floppy disk and your all good to go. If theres any probs do the flash again but this time with your original bios.
