may i know wat is the best bios to pair with UTT & amd64 3500(caa2c) proc on dfi ultra-d sli
thx
thx
try the 704-2 bios
The bios you are recommending could kill the CPU if Special VID is at 123% or above. They'll be a revision in a week or so.Quote:
Originally Posted by pershoot
Ive actually flashed away from that bios and didnt even wana take the chance of using a different vid combination.. Too scared to kill my precious sandy.. :)
the 706 is the 704 with out 116% and above for special VID control, works fine and is safe, but still puts some high volts through your CPU regardless.
My advice is for everyone to stop using 704 and wait for the replacement from oskar wu, he's working on it.
??? I am not reccomending anything. I have 'added' the bug statement and the bug link to the ISO and the -mini.Quote:
Originally Posted by soundx98
no no pershoot. You are doing great!
I was referring to the post from 187(V)URD@ as I was not sure he was aware of the 704-2 issues. I was quoting you to point out the warning.
:D Hehe - bad birds & longnecks say OSKAR wanted to force AMD's CPU sells with the last BIOS revision........, :p: but in my opinion OSKAR wouldn't do such things anyway :D :D :D
:toast:
ahh k. sorry for the misinterpretation.Quote:
owh i didn't know that about that bios.
But i am no longer using BH5 anymore but TCCD and since i never had TCCD what bios can you recommand for now?
Ive been using the 623-2 for my bh5 and tcc5..Quote:
Originally Posted by 187(V)URD@
For OCZ 3200VX is good 623 official bios?
I am running the UT SLI-DR with 2 sets of OCZ4002048V3DC-K it is 4 1gb sticks and an X2 4400+
What is the best bios for this combination?
try the official 623, its the most balanced of all the bioses so far. not to mention it wont toast your CPU like the naughty 704 :D
:D In my opinion it's 510-2FIX.Quote:
Originally Posted by Mussels
:toast:
Does somebody know when oscar will have the bug in the 704-x Bios fixed ??Quote:
Originally Posted by EMC2
Yep, he does... :p:
Ive been using 623-3 and it's been giving me a hard time. My computer crashes on Windows splash unless i tweak the hell out of the memory settings - and that's at DDR400 (I have DDR550 TCCD)
i'm on UTT (OCZ PC-4000 Vx) so maybe thats the diff.
Just moved over to some PC-4800 samsung TCCD and its flying on the bigtoe modded 704 tho.
You said 704 is dangerous and still you use it :p :stick:Quote:
the bigtoe modded version does not include the dangerous CPU voltage options. therefore, while max voltage is limited, its still quite safe to use.
I've attached it here. This is exactly the same as the 704 that was recalled, but all voltage mulitpliers above 113% are removed, because those are the ones that did damage.
i still recomend that you use higher core voltage rather than the special % increase ones.
edit: "file is too large" bah, someone let me know who to PM it to...
mail me the bios :)Quote:
^ sent to "187(V)URD@"
Would be a good idea to remove your email address from public view now, or you'll just get your ass spammed.
ty done :DQuote:
