Well, your CPU warranty is void if OCed, but did that stop you? Well, the sticker on the maze4 shouldn't either.Quote:
Originally Posted by xenolith
As for barbs on the storm, it's not necessary, but it offers some benefits.
-more durable. the plastic barbs may crack or warp after time.
-looks much better
-EK barbs provide less turbulence due to slightly bigger OD
Also, from Mr.VirtualRain:
Also, you won't believe how dirty your blocks are if you've never cleaned them....Quote:
Material: Plastic vs. Metal
Plastic fittings can be nylon, poly(something), or acetal. Most Swiftech stuff comes with plastic barb fittings. The main consideration in using these kind of fittings is that if you are using the widely recommended 7/16" tubing over 1/2" barbs that are plastic, you will not be able to easily remove the tubing once it is on. In fact, you will probably have to heat up the tubing to get it soft enough to put it on and then you will likely have to cut it off.
Metal fittings are typically nickel plated brass. They look good and have the benefit of allowing 7/16" tubing to slide onto 1/2" barbs forming a good leak-proof seal (even without clamps) yet the tubing can still be pulled of with some force without damaging the fitting or tubing.
