[QUOTE=Major]Thanx!Quote:
Originally Posted by ArcticOC
Nope, i made the hole thing using:
- circlesaw (for cutting metal pipes/profiles)
- table drill
- flexi cutter
Mostly normal tool`s found in a standard garage
Don`t have a CNC bench :(
- table drill
- flexi cutter
Thanx!Quote:
Originally Posted by vapb400
I`m already registrated on SPCR.. But I don`t like that forum :stick:
The posting rules there is too damn strict and some of the moderators is so damn picky. I havent fealt welcome there since the first day I posted on that forum. And the quality level of the users there is not so high, no spectacular mods, I`m easely beating the top clocks there with my system :fact:
If I post a worklog I rather do it here :toast:
My main forum is in Norway (forum.hardware.no) and all my DFI mods is in this tread: http://forum.hardware.no/index.php?s...378691&st=2257
I just added after market ram sinks and let my 7700 blow on them...
Nothing you already haven't seen. Still though this 92mm fan keeps the whole area nice and cool. Even when running 3.5vddr the pcm chip is kept under control. A thermal probe attached to the heatsink right next to the ram slots without the fan registers 80+°c and with the fan it's in the 40's. Show's what some active cooling can do.
I know exactly what you mean actually :slapass:Quote:
Just ghetto fitted a small deskfan to the side of my case to cool that toasty BH-5! :D
[img][/img]
that is a forumer in m'sia do...Quote:
Originally Posted by DriveEuro
he is great in those kind of job...
dymONE that is one hell of a crazy ram cooler! :o What are the temps of the ram now? And did u gain any oc by using this bucka!?
I just attached 2 A64 stock fans to the top of the Big Typhoon. Ghetto but effective...
http://i14.photobucket.com/albums/a3...s/CIMG0415.jpg
dymone is that a slot a cooler from micro center? I almost bought one that looked exactly like that after seeing yours, but decided I'd verify.
*edit*this one:
http://microcenter.com/single_produc...uct_id=0148853
No .. that is a heatsink from P2
have 2 120mn fan blowing on it, sry for the bad quality pics, its taken by a webcam wat do u expect eh?
Did you gain any mhz with this type of ram cooling ??Quote:
Originally Posted by dymONE
My ram cooling is pretty simple: 2x 80mm fans do the job :)
Just finnised my ramcoolingmod =) What do you guys think?! (havent tryed them out yet)
http://files.upl.silentwhisper.net/upload0/PA180074.JPG
http://files.upl.silentwhisper.net/upload0/PA180078.JPG
My case is under construction =P a bit messy...
First of all, Welcome to the forums :welcome:Quote:
Originally Posted by general1
That mod is really nice. How did you make the stand? :)
Thanks OV3RCLOCK3R :D
This is what i used: http://files.upl.silentwhisper.net/upload2/PA190072.JPG
And how it hangs on the board:
The frame is slightly smaller than the ramslots, so it snapps on... on the ram "snappers" hehe. Bulletproof solution :)
Very nice crafmanship, although it seems that not all the chips make proper contact?
Did you gain any more MHz on your ram after this mod?
