Originally Posted by chew*
*update*
Tried changing the uniprocessor driver. *WARNING* If you are running raid do not change this driver your sytem will not boot up again and unless your good at hacking your windows you will be forced to reinstall.
2nd issue.
I discovered that the sata raid driver provided by gigabyte is junk. Using this driver will corrupt and or cause permanent damage to your hard drives. Use the silicon images driver provided by MS in they're auto update section. I have tested it and you lose minimal performance but gain maximum stability.
Example of issue with the gigabyte supplied driver. When running in raid 0 if you run sisoft tuneup wizard you will be given a BSOD right near the end of test.
I also experimented with some third party drivers for nf3. In games it would cause my game to freeze. I am now using a whql certified nvidia driver version 5.10. The driver i tested was a 7.xx series.
Will tackle the ram issue over the weekend with dualsided ddr dimms.
