Most 939 boards that I know off all work like they are supposed to at default settings... NF3 or VIA KT800PRO
Any one should do you fine. Abit, MSI, Asus
Hey HK I got the the EPOX 9NDA3J rev 2
It's basically the 9NDA3+ at $40 less money
Missing FW
Missing rounded cables.
Missing Firewire headers
Missing Screwdriver
Only 2 sata NV RAID vs. 2 sata NV RAID and 2 marvel
Other than that it's exactly the same board. Same box, Same bios options, same layout.
Problems so far? same as 9NDA3+
-slots 1 and 2 don't work even at stock speeds has memtest problems
-Slots 3 and 4 are OK with TCCD until you push past about 230Mhz then it really don't like 1T no matter timmings...
-NO 3.3 or 12V monitoring. If you see it, the numbers will be crazy as hell.
Good things?
-more Vcore options up to +.35 in .05 increments
-Posts no problem at 325HTT and works well at 315.
-Works up to 280 with 4HT!!!
Hope this helps... Killer board for $90.
Sorry guys, I've been busy with other things. Haven't been keeping up to date. Starting to catch up now.
NB HSF maintanance class:DQuote:
Originally Posted by Swing
orange pci slot is for the MSI WiFi card.Quote:
i wouldnt use that slot at all...
ive heard it could effect your oc (instability)
so why take the risk :)
hey guyz!
can you help me getting my ABIT AV8 stable?
my problem: fastwrites disabled, everything correctly installed. so far, so good. then i put in my win xp professional cd and install it. after i have typed in my name and the networks informations, the installator says --> 7 minutes remaining (in the left down corner). so far so good. after this, i get a bluescreen, which says, change your videocard, disable drivers and reboot the system. i tried everything, but i still get this bluescreen!
HELP ME, PLZ!!!!!!!!!!!!!!!!!
best regards,
burnhead
Thanks Jack!
I have another question: :p:
How many SATA's does the Neo2 have?
And how many of are locked?
Thanks :D
np :toast:Quote:
need a small help... My K8nsxp died today (at least it won't make me lose time anymore...) i need another mainboard but i can only find an Asus A8V or an Abit Av8. I have to wait a week to get an Msi... What would you do... wait or get a Kt800 mainboard?
I need them to achieve something better than the 3ghz i got with the Giga... so consider that the priority is overclockability
Thanks for the help :)
i would get one of the newer MSI's, with serialnumber 0410 or higher :toast:
those new boards will do real nice :D
Once I thought that Neo with S/N:0411 are new rev's, but I got S/N:0410 with the new revision from Taiwan.
So there is a non-wi-Fi veriosn and a wi-fi?Quote:
Originally Posted by mdzcpa
Deluxe has the wifi, and is about 15% more money, well at least where i get my stuff
Thanks. I'm up-migrating from nf2 to Socket 939 and I am looking for a stable, mature, board on which to use these components:
ATI Radeon 9800 Pro Sapphire
Original Corsair TwinX PC3200LL rev 1.1 BH-5 2 x 512M 1G Kit
NEC DVD-RW ND2500-A
Informed recs much appreciated.
Cheers,
Allan
Well, the NF3 boards are better feature-wise than K8T800, and seem to overclock better, but are more expensive. At my supplier, Abit AV8 is 20% cheaper than the board i have - the MSI K8N Neo2 Platinum, which is serving me well (although it has its fair share of bugs\annoyances, like dodgy readings and cpu socket placement)
I like the Abit boards that I have used but wonder about the companies future after hearing about "Enronesque" financials. I have been reading this thread and am leaning towards a revision 2 Asus Boad. I don't really want to mod it much and want a feature rich board to setup with a new Winchester CPU. I fear the Asus board won't like my RAM though?
OK something weird is going on here (K8N NEO2)
Vcore @ Bios is 1.5V
Vcore @ CoreCell shows <1.5V (but options shows that 1.5v is selected)
Vcore @ CPU-Z shows <1.5v
Vcore @ ClockGen is 1.45V
It makes me very uncomfortable because I don't know if my chip (which is 0431 :( but I have some hopes on it) can do 2500mhz @ 1.4XV OR 1.50V. If it's really under 1.4v currently i'll give him 1.5v and im sure he'll do 2500mhz at least.
Can someone help me out?
Thanks in advance :D
Hmm... can you help me i have some big problems getting my 2*512mb OCZ 3700EB ram to go parst 250Mhz 1:1 on the MSI K8N-NEO2 with my 3200+ Winchester....
i have tryet bios 1.2 and 1.3 and 1.5x(the last one i find)
sorry for my bad english. :(
by the way i have even tryet with my OCZ DDR-booster to give the ram 3.2 and 3.3 but that was no good... my winie is a middle ting i think... it is able to hit 2.75ghz with 1.65 in v-core an are game stable there...
The Neo2 undervolts by about 0.05, so giving it more volts is fine, swing
And that is @ 1.45 Vid. Must use vid % to get higher (though I don't see why it's needed ;) (insert smirking smiley here (sig))
Hi,
I have some questions about MSI's K8N Neo2 Platinum.
As far as I understand, you need to bend one of the caps to mount an XP-120, right?
So, do you think I should get XP-90 and save the "risk", if any? :confused:
Or maybe the cooling differences will be to big to lose just because of a single cap?
Also, does the MSI stock NB hsf worth's something?
Or should I upgrade it?
Thanks in advance :worship:
Swing.
The NB HSF usually doesnt have proper application of thermal paste, from what ive seen. lol. i may check my own at some point. Apparently the NB fan has a short lifespan, though its not difficult to replace. Probably better to get the smaller XP-90 rather than taking risks with the 120 and possibly damaging something.
Swing, there are pics of a mounted xp-120 with the bend cap on the internet.
Search for it and decide if you 'dare' to take that step and bend it :)
difference between xp-90 and xp-120 is undoubtly tested by someone,
just google for it ;)
g/l
Jack
Whats wrong with my MSI Neo2 54G:
Cant past 1.55V+10%, if I put 13% or above and save&exit it will be 1.55V "By CPU Vid" :mad:
Flashed with WinFLASH -> 1.36b, 1.37 and 1.41 :stick:
* Antec TrueControl 550W
* Msi K8N NEO2 54G Platinum
* 2*256mb KHX3000 BH5 SS, MemTest86+ #5 2hours S754 cas2-2-2-5 1T, nF2 271FSB cas2-2-2-11 Dual 1:1, cant be the mems :)
Have you ever tried using CoreCenter for adjusting vcore?
take a look here :)
