A flash isnt going to help you kryptobs2000, That is BS, ZipZOOM's disclaimer "not responsible for typographical errors" doesnt fall under this. Mostly everyone is getting 325/1100's The memory is what makes this card.Quote:
Originally Posted by kryptobs2000
I wish you the best of luck in fixing this matter. a 325/700 card should go for about $249, i bought a BFG 6800 something last month for a customers computer that was around this clock speed.
I go through a lot of cards and pick and choose the cream of the crop for mine. I understand a lot of you, or new/young overclockers that might have to save their money for a month or longer to buy this card. And you make your desicions very wisely. And it sucks to be dealt this card, This isnt taking a chance on buying a x800 and hoping it will flash to a XT/PRO/PE, this is a card that's advertised @ 325/1100.
I finally got kicked out of 3dmark. I cranked it up to 485/1275, it's artifacting very little but would've made it through the test. but i got the error.
Not enough power to run the card, Vid card needs more power. I guess it's really pulling juice running it.
And no BS, im running this dual Xeon 2.8 @ 3.6ghz Dual chips and the 6800 card off a 300 watt fortron Aurora. I just switched it for a fortron 350 watt aurora and it's running fine now. I have a couple of 530 fortrons here. that i'll switch to. When i get this all mounted in a case. I've got a couple of swifty waterblocks for the chips. Im hoping for some more mhz out of them. I havent volt modded the board yet. and they are on air now.
So what do you thing EVGA is going to do for you, No bios in the world is going to get your card up to 1100mhz stock rating. They need to ship you another card. If i had any left i'd hook you up if Zipzoom would refund you money, But i only have mine left. And now im worried about ordering any more. Zipzoom's RMA dept. is a real "BICCHH"! compared to newegg.
I got a bad asus PCDL 3 months ago. It's a duallie board, They told me it was special order and i had to RMA to ASUS, I dont know how they call it a special order when i ordered it right off of their site and they keep them in stock all the time?
BS i tell you!!!
