w00t, that's the way I like it! :toast:
:toast:
It gives me 33°c idle, 38°c full.
Rofl:banana: :clap: :clap:Quote:
Originally Posted by Shinuza
Hows it clock with that on?
Woah! thats one hell of a cooler! Sure beats the hell out of the "dustbuster" i created by adding a 80mm Panaflo U1A fan to a dead Arctic Cooling Silencer after taking the stock fan out of it.
http://www.kalionzes.com/computers/Panacooler.jpg
New case
http://i1.tinypic.com/nmgold.jpg
http://i1.tinypic.com/nmgpd0.jpg
Will post watercooling pics once new CPU block arrives.
http://i28.photobucket.com/albums/c2.../Imagem179.jpg
http://i28.photobucket.com/albums/c2.../Imagem159.jpg
http://i28.photobucket.com/albums/c2.../Imagem196.jpg
sp-94/tornado 80mm
opteron 146 @ 3.2ghz
vcore 1.48v
idle 33C
full load 44C
room temp 19C
nice moniter :P
685/1380Quote:
Originally Posted by Dr_at_Home
4th all around 6600 GT -> 3d05
Full air :)
Nice:clap:
How did U mount Freezer on?Quote:
Originally Posted by ArcticOC
Which Freezer is that?
Here is my mod :D
only 80mm fan on Hiper is a bit loud :( but i'll try to fix that!
http://img110.imageshack.us/img110/1...eno18am.th.jpg
http://img235.imageshack.us/img235/2...jeno6ya.th.jpg
This is my rig
http://img.techpowerup.org/060211/DSC01289.jpg
http://img.techpowerup.org/060211/DSC01293.jpg
http://img.techpowerup.org/060211/DSC01292.jpg
Idle :D
http://www.xtremesystems.org/forums/...1&d=1140138807
Full CPU gets up to 35º im in summer right now ambient temp here is ~25º
Delta Triple-blade High Speed fans at the front and on CPU, Enermax UC-12FAB fans at bottom and back and Enermax UC-9FAB fan on side panel.
http://img232.imageshack.us/img232/4292/myrig0589ly.jpg
http://img162.imageshack.us/img162/2...demypc29xk.jpg
Added 600gramms of copper to my 6800GT :toast:
http://www.tmmtmm.org/files/P1010005.JPG
http://www.tmmtmm.org/files/P1010006.jpg
http://www.tmmtmm.org/files/P1010007.JPG
Jesus F*cking christ! :eek:Quote:
Originally Posted by TMM
How does it handle the weight???
And how are temps :fact:
Nice clean mod ;) :woot:
Best regards :toast:
no probs with weight - previously had the stock leadtek cooler which weights about the same :toast:
Temps are down from 50C idle, 70C load on stock cooler to 45C idle 56C load :woot: (Ambient temps are 28C :cool:)
i should have 1 of the best air cooling setups on the forums. specs in sig, also video
http://img133.imageshack.us/img133/4...ture0102gk.jpg
Too loud! That CPU heatsink is only meant to remove so much heat...simply putting a larger fan on it won't help...you'd need to switch to a different type of cooling.
rofl not really. i think im doing preety good at 35c idle for a P4. before it was idling at 53c. now it doesent even go up that high for a load temp. doesent even break 51c full load.Quote:
Originally Posted by Nicksterr
dude that is bad ass :D nice job! very clean.Quote:
could we stop quoting pictures?
well i guess its good for people to see some nice pics again from previous pages.
Could we loose the 56K and get some broadband?Quote:
Originally Posted by Magnj
Your PC sounds like a freakin' jigsaw. :eek:Quote:
Originally Posted by ingentingmendeg
Uh.. that coolermaster case is crap without a fan over the videocard.Quote:
