You would be better of using the modded GT bios, it gets you 300points increase in 3d mark 2005 at same clocks as default Ultra as it has tighter ram timings, i have this bios and have modded to 1.6v and have no issues of heat, at 465/1225mhz, if your gonna o/c slap some artic silver or ceramic on core/ram and volts mosfets.
I can make your bios 1.6v but not 1.5v as tool dont support or i can give you the modded GT bios with 1.6v,you card will be seen as a GT in windows until you tell rivatuner to rename it to a ultra this requires unistalling/reinstalling driver as we technically are changing card.
Its a 5min job at your end and worth it even if you didnt overclock or raise volts the GT timings gain you a good jump for FREE.
