Yes, you mean gaming CARD: Titan, Quadro for best price
Attachment 131327
Looks pretty slick :cool:
Haha you guys beat me to it by seconds haha
"Haha you guys beat me to it by seconds haha"
Seconds are important...:lastweek:
/jk
I sense the first stirring of unease in the Nvidiasphere :caution:
Size of a Hynix GDDR5 2Gbit IC is 14x12mm ;)
I think a 512bit memory bus is kind of excessive unless AMD architecture is that reliant on it. I think this kills alot of the bigger spec improvements because such a size bus is going to take up a crazy amount of room.
Dang I was hoping to be surprised...almost made it lol
Yep that's 512bit memory, each chip handles 32bits of the crossbar.
crazy ...
512 bits bus back again !!!
with bf4 OMGGGGGGG
Tahiti sized PCB.
8+6pin
6+2 PWM
Looks like 2 DL-DVI + other outputs (yay for when I get my QX/DP2710)
16 memoy ICs all on front, none on back
Has some sort of mod to it, soldered wire.
Also has a switch on it too, maybe it has dual bios...
You think AMD is going for 512bit memory now, because being able to transfer a lot of graphical data will become more important, as next gen consoles will be using much larger textures etc as compared to current gen consoles?
AMD is going for 512-bit for two reasons:
1. HPC
2. Efficiency (low clocked 512-bit probably consumes less energy than 384-bit with high clocks)
Most likely, they're going 512-bit because:
-They have a big enough perimeter to do so
-They can fit that 512-bit bus in the same or less area as Tahiti's 384-bit bus, as per Dave B
-4GB of memory is a good sweet spot -- 3GB would be underwhelming, and 6GB would be largely unnecessary
-More bandwidth will help with ultra high resolution gaming and performance in general
-A 512-bit interface with slightly lower clocks is probably more energy efficient than a 384-bit interface with bleeding edge clocks
Looks like a solid design choice overall.
hopefully the cooler fan isn't as loud as the 7970's was.
i can see it now this card beating the titan but having a loud cooler and getting horrible reviews lol
It looks quite promising. Beating Titan seems possible.
I have a Geforce Titan but I really hope this AMD card performs really well. We need the competition to move things forwards. AMD already :banana::banana::banana::banana:ed up the Desktop CPU's :(
