how do you know?
random 1600C7 are more likely to be made past week ~1020 and hence have T-PSC
tried 2 and both were x
both 2600 8-12-8-28-96 wcl 6 1.90
for 40 euro per kit i would try if someone look PSC
Main problem is age - if these are newer batch, they are most likely T-PSC or some real bad Elpidas - risk is high, but no risk no fun :D - offer is for gamblers^^
I have 8 sticks, All X series....but all 6 layer pcb :X
ooh sam need your help on some PSC / BBSE kingstons for that super kingston competition at hwbot, do kingston have samsung memories too?
PSC you will find on Values, apart from that T1 2133 and 2000 9-9-9 are (bad :D) BBSE, 2250 and 2333 T1 clock quite good, most likely are BDBG, but my 2333 kit clocks like good psc and easily does 1300 8-12-8-28 on air, 2250s I had I only tested fast for 1000 6-9-6-24, easy, so potential was there. Samsung are on 2666c11 Predator for example, but tests were not convincing...
Only saw them on values, a few did quite good - here is 1333 with psc
http://abload.de/thumb/kingstonkvr133312568-nxs6p.jpg
Quality varies enormously, due to ICs being not binned. Most were not very good
problem is bdbg 2gb sticks are single sided right?
No, BDBG is 1gbit IC like BBSE and PSC, the 2gb sticks are dual sided. Afaik, Powerchip semiconductor developped under license from Elpida X-Series out of bdbg /bbse, which explains some charactersitics being very similar like firm TRCD walls and sometimes trp having to be above cas on some ics
P.S. 2333 1gb is single sided, these might give you hard time at reaching good score on 32m
edit:
thanks for info websmile!
http://item.ebay.com/141076320104
Micron D9JN_ (most likely)
http://item.ebay.de/181225851918
Elpida MGH Hypers
http://item.ebay.de/221289138268
http://item.ebay.com/181227563324
Elpida BBSE
http://item.ebay.co.uk/171138649877
Elpida BBSE (probably)
http://item.ebay.de/181228652456
Elpida BBSE or X-series PSC
http://item.ebay.com/271288131456
http://item.ebay.de/200970137161
http://item.ebay.com/271286711199
X-series PSC
http://item.ebay.com/251351276821
http://item.ebay.com/151131584479
X-series PSC (most likely) or T-series PSC
http://item.ebay.com/141078720495
http://item.ebay.de/121187882255
http://item.ebay.de/331034822880
http://item.ebay.de/200969740205
X-series PSC or T-series PSC
http://item.ebay.com/300979710658
http://item.ebay.de/261297468913
http://item.ebay.de/221292186901
http://item.ebay.com/360753950023
http://item.ebay.com/231063928423
T-series PSC (most likely) or X-series PSC
http://item.ebay.com/171139785599
http://item.ebay.de/321220345179
http://item.ebay.com/231065014054
http://item.ebay.de/251348760076
http://item.ebay.de/271287290359
http://item.ebay.com/290987094795
http://item.ebay.com/121186147453
http://item.ebay.com/151132201794
http://item.ebay.de/251351274551
http://item.ebay.co.uk/231065323048
Hynix 2Gbit BFR
http://item.ebay.de/380735397192
http://item.ebay.de/380735396190
Hynix 2Gbit BFR or CFR
http://item.ebay.com/321217962881
Hynix 2Gbit CFR (most likely) or BFR
http://item.ebay.de/221290458026
http://item.ebay.com/121186145170
Hynix 2Gbit CFR
http://item.ebay.co.uk/261297663882
http://item.ebay.de/251348210945
Hynix 4Gbit MFR
http://item.ebay.com/221291695169
http://item.ebay.de/290987408002
Micron D9Pxx/Qxx
http://item.ebay.co.uk/251349054268
Samsung 2Gbit C-rev
http://item.ebay.de/261297331958
http://item.ebay.com/200969579000
http://item.ebay.de/141074215987
http://item.ebay.com/151132160066
Samsung 2Gbit D-rev
Anyone have a clue on adata serial numbers?
Not the model numbers but serial numbers.
http://item.ebay.com/231069309308
Micron D9GT_
http://item.ebay.com/231066684580
http://item.ebay.com/221293883350
Hynix 2Gbit BFR
http://item.ebay.de/380735398943
http://item.ebay.de/380735398168
http://item.ebay.com/111181162389
Hynix 2Gbit BFR, CFR or Samsung 2Gbit D-rev
http://item.ebay.de/281182312201
http://item.ebay.co.uk/261296787346
Hynix 2Gbit CFR
http://item.ebay.com/380734689894
http://item.ebay.com/131008618458
Hynix 4Gbit MFR
http://item.ebay.de/251348542290
Micron D9Pxx/Qxx
http://item.ebay.com/271292444799
Samsung 2Gbit C-rev
http://item.ebay.de/321218818719
http://item.ebay.com/151135244407
Samsung 2Gbit D-rev
so kingston doooo have some MFR?
double sided poop
dont be fooled on that one
"The Box Includes: One 8 GB Memory Module. "
yea,,,but not single-sided 4 gb modules :)
im confused, so double sided MFR is bad? bad clockers?
Have anyone tried these: http://www.newegg.com/Product/Produc...82E16820313322
Team Xtreem 2666 MHz CL11 2x4GB
At least for the price I will take my chances :). Ok, is not something cheap, but has high chances to have Hynix MFR. Sorry if this link was posted long ago ;).
mfr indeed,it is very cheap!
As Alex-Ro has stated, these are MFR based. First link below shows pic of two versions...earlier one with green PCB and newer black PCB, which is what the Egg currently ships. Second link is to a short user review (green PCB version) posted over on OCF (Overclockers Forums). Third link shows results with the M6I mini board.
http://www.xtremesystems.org/forums/...=1#post5199271
http://www.overclockers.com/forums/s...d.php?t=728364
http://www.xtremesystems.org/forums/...&daysprune=365
Edit: This link has pics of the ICs. Took me a little bit to hunt it down, so now it is bookmarked. :)
http://www.xtremesystems.org/forums/...=1#post5191795
http://item.ebay.co.uk/271292266592
http://item.ebay.com/141084708138
Elpida BBSE
http://item.ebay.com/181230156863
Elpida BBSE (possibly)
http://item.ebay.com/271293477708
X-series PSC
http://item.ebay.de/121191102971
http://item.ebay.de/161118421461
X-series or T-series PSC
http://item.ebay.com/151137047164
Hynix 2Gbit BFR
http://item.ebay.de/380739513748
http://item.ebay.de/380739513460
http://item.ebay.com/161120508565
http://item.ebay.co.uk/111184909513
http://item.ebay.co.uk/321221623373
Hynix 2Gbit CFR (possibly)
http://item.ebay.de/271290783487
Hynix 4Gbit MFR or Samsung 4Gbit B-rev
http://item.ebay.com/121188513319
Micron D9Pxx/Qxx
http://item.ebay.de/221294916175
Samsung 2Gbit C-rev
