Has anyone else received more WUs since that small amount a few days ago?
No, haven't seen any after that.
All 3 crunchers are back to 100% cpu work.
No GPU WUs since then.. In the next 1-2 days, the largest deadlines will expire, so something might appear.
I barely have enough tasks to past the 200K tasks for HCC. I'm happy with how everything turned out. I hope more projects come down the pipe soon, but in a way I want to crunch for the other projects that I've neglected.
Got 33 resends today on my Nvidia cards:up:
my main ran dry while i was at work :S
Thank god it's almost over... (got about 8 hours left)... it's something like 50C in my room.
Dry as a bone here :(
Just got 35 more in the last 2 hours :D
There is something you can do to increase your chances of pulling repair HCC tasks.
In Windows you can set up a scheduled task to have BOINC issue an update command every x minutes. That will get around the problem of BOINC taking increasingly longer times between updates when it receives no work from the server.
Set up the task to be executed as:
boinccmd.exe --project www.worldcommunitygrid.org update
The command must be started in the BOINC program directory.
Also, do not issue it any less than every 3 minutes. WCG increased the delay between updates from 11 seconds to 2:01 minutes. If you issue a update while the delay is in effect the server will reject the update and you'll never get any work.
The same thing can be done in Linux but because of my limited Linux knowledge I've never been able to get a daemon to work the way I want it to, but if you know Linux it looks like it should be pretty straight forward to do.
Bill P
http://www.wcgsig.com/402500.gif
Just when I got a gtx670...
You can always burn it in on GPUGrid or Folding@Home for the XS teams.
I'm out as well. It looks like it will be a slow trickle of WUs until the very end. It was a good run, and my hat is thrown in on this one.
