its weird that you and charles are having same issues. that ud3h is so tempting! :D
lol^
btw, what bclock you on mike?
owikh84 - 6:26:750 - 50x100 - 1333MHz - 10-12-12-25-107-1 - Asus Maximus V Gene - Team Xtreem 2600C10 2x4GB - 1.68V Air Cooling
http://i458.photobucket.com/albums/q...0-12-12-25.jpg
Freshly installed MicroXP 0.86 32-bit
No chipset driver, just USB mouse & KB drivers
No AI Suite etc
No wazza
Large Size Cache & NoPageFile registry tweaks
But MemTweakIt is not working
Drop me a PM with a list of the OS "tweaks" you are using plus UEFI screenshots of CPU config and memory timings (include the timings you are using for the run itself).
What Gungstar said above is correct also. :) To me this seems like a possible UEFI config error and a combination of incorrect memory timings for the frequency used. Get those wrong and the scores will tank.
yeah 100 will have a worse CBB and CB
try using 105+
Don't use CAS 7 Trans, it's copy is far lower here than C8... you just need a good ram set for this... my TridentX's ( similar to yours, are the best out of my ram sets. ) but don't go TRCD 12 on air at all. Massman still has the BBSE and the good Samsungs RipjawsZ, but to get sub 20 sec needs mega tweaking and/or chilled dimms...
I also saw you were using 4 cores and HT on, set 2cores and HT off... 1 core is again slower then two...
Leeghoofd - 6:25:594 - 48x102.1 - 1389.5MHz - 11-13-12-18-100-1 - Asus Maximus V Gene - G.Skill TridentX 2666C11 2x4GB - 1.82V Air Cooling
Attachment 127102
No wazaa or nothing, just enter and run...
do you guys accidentally have extreme tweak setting?
I have it enabled, but haven't tried without it.
Just fiddling about with the UD3H. The board is really starting to grow on me! :-)
Still some subtimings to tweak. Maybe I'll shoot for a 1400mhz run first.
http://hwbot.org/blog/wp-content//621234.jpg
-updated
*the Belgians have landed!
I tried cas 7 and 8. these are psc im on right now. shamino said to enable cstate package support.
I appreciate all the help guys. Its going to take a while to try all these settings and report back. I'm so tired from being up last night. I need a 2nd wind.
Hmmm - what's CBB again?
http://youtu.be/CYmIF5OwhXY
^^ thats unbelievable!
hey mike i have spare torches. i can send you one :D
I need better memory :(
I.nfraR.ed - 6:19:719 - 50x100 - 1300MHz - 9-11-8-22-72-1 - Asus Maximus V Gene - G.Skill Trident 16000CL9 2x2GB/BBSE - 1.84V Air Cooling
Attachment 127114
Good job Infra.red, at least I'm the fastest with C11 :p
Or you can try freeze them infra, maybe it will help :)
owikh84 - 6:22.687 - 48x104.2 - 1389.5MHz - 10-12-12-21-128-1 - Asus Maximus V Gene - Team Xtreem 2600C10 2x4GB - 1.87V Air Cooling
http://i458.photobucket.com/albums/q.../IVY/27772.jpg
