Would you rather see 1024x768 0xAA and 400fps on the intel cpu and 300 fps on the AMD cpu?
Yes, because that actually says something. (all settings maxed ofc)
I would like to see the cpu test and not gpu built-in benchmark
I was thinking the same thing, but JF-AMD stated outright (to me, IIRC) that no such thing was happening, but that the BIOS updates could make a considerable performance difference do to the CPU initialization code. Also, Windows and Linux need kernel scheduler changes and memory alignment changes due to the share L1 cache causing excessive cross invalidations and subsequent reloads.
The cache memory has significantly more latency, but about a third more reading performance. Writes are also slower, which explains the presence of an L2 WCC (write coalescing cache). The very existence of the WCC and the cache details made available long ago made me wary... 18-20 cycle access times vs 12 cycles on Phenom II seemed like a BAD idea... that, and they kept the specialization of the ALUs instead of making them more capable, then removed one... but added an extra pipeline... that didn't seem too bright either, unless you can use the ALUs across the whole module to make a fat core (which should have been done before releasing this product).
If this is indicative of Bulldozer's performance, I will be building Intel machines almost across the board because the 1155 upgrade path is strong, but AM3+ is weak... a few of the lowest end machines will be AMD... but Athlon IIs.
My media machine upstairs is being prepped for an $800 upgrade and I was hoping Bulldozer would be the core, but it looks like an i2600k will be there instead - which sucks, because I have to pay a premium for the other features I need... but the performance is what matters for HD video.
--The loon
Some dude is doing live stream benching Bulldozer , with 8 threads he got 24 GFLOPs :shakes: in LinX 0.6.4
bulldozer online: https://join.me/573-962-519
In what?
Wow. I sure hope there is just something wrong in the BIOS, or maybe a new stepping is needed.
I was really hoping to change camps.
Yes it would tell you how the chip handles gaming at settings you'll never play it.
In these 6 tests the BD cpu averaged 130 fps with AA. The i7 averaged 131.5 fps with AA.
Answer me this - if that BD chip was $50 would you even consider buying anything else for gaming? What about $100? How much is that 1.5 extra fps worth? This is the reality of enthusiast gaming, not ridiculous 600x480 resolutions.
No! It is important that it runs games at normal resolutions as fast as the fastest phenom as long as it wins in BF3. BF3 is the key because that is using new technology. It seems that it wins over phenom in all games and in some games it wins over 2600K, this is very good.
All credit geos to black96ws6 on Overclock.net
http://www.overclock.net/amd-general...s-benches.html
Screencaps so far:
Attachment 121031Attachment 121032
Attachment 121030
Attachment 121028
Attachment 121027
Attachment 121026
Attachment 121023
Attachment 121024
Attachment 121025
Attachment 121029
hes installing vantage now.
Why does the task manager not show 100% utilization?
dont forget this video someone made right after that FX-8120 CB run was done,its mean but funny as hell
http://youtu.be/CqTU4wVvZL0
Why are you arguing cpu performance with gpu performance?
The cpu does the same amount of work regardless of resolution (as long as all the other settings are the same)
Yes, a game wich has 3-400fps with 1024 resolution is rather pointless, since you obviously dont need much cpu performance for it to run great. But what if you get a game that runs with 100fps, or 50fps @ 1024?
Thoose 300 and 400fps would tell me SOMETHING about what to expect, while those 130 gpu limited fps you want to see wouldnt tell me a daam thing about cpu performance in that game.
All that 130fps shows me is that both cpu is enough for that game(but nothing about newer/more cpu dependant games).
Wait till the "hittler got told" stuff pops up...
Exactly, it just tells you right now the cpu is "good enough" what happens when you buy half a year later another gpu and run cf/sli, or when a game finnaly starts to be more cpu dependent (like SC2).
With lower res benches you see what potential the cpu has, with caped max res benches it all looks the same.
thats awesome :rofl:
Indeed funny.
BTW, anyone know why the CPU is hardly strained in some of these CPU intensive benches?
hahahah, that clip made me laugh alot too :D
