I suspect that using a "fixed" spare-area vs RAISE was based on findings and it could be a wise decision.
There is no compression going on "in-memory" and so both the pagefile and the hibernation file should be easily compressible.
In the end it's all highly dependent on what data the user processes, I for one am using the SF drives for VM's (data and code is highly compressible) and so I'm pretty sure that WA is well below 1.0, most likely between 0.5 and 0.7.
In my case, 90+% of the contents are somewhere in between 46% and 8% (based the compression ratio used in my benchmark) and so it is definitely performing a lot better than incompressible data would suggest.
I'll make sure to check flash writes vs Host writes at first opportunity.
As of Office 2007 one can't really compress the files by 85% as they are already compressed, unless one uses the old format :). (some are still using the old format, not many I suspect)
I haven't checked ODF though, I would think it does compression as well.
I suspect the SF advantage is more likely to be found in "business" scenarios rather than the typical home user working with a lot of incompressible data like video/music/images, otoh, most users are using HDDs for "storage" rather than SSDs so there might not be that much incompressible data on SSDs.
I've been thinking of creating a test based on populating a database with data and then performing some tasks on the data, it would be the most likely scenario where SF should show it's strength vs others. (could be real life tasks like importing/exporting/searching/updating/indexing/... data)
