If you click on the Digi+VRM/Power Control button and change the Vcore Phase Control setting from "default" Extreme to one of the other selections it will then allow you to select either manual vcore or offset vcore back on the first Extreme Tweaker Tab menu.
@l0ud_sil3nc3
Offset vcore is working fine for me with a milder 47x daily "crunching" o.c at ~1.31v load.
