Yeah windows Supreme custom made with SP1 Build in!
Here a 5Ghz 1.35v LinX stable and Intelburn stable using all the memory have got and the higest setting!
http://img834.imageshack.us/img834/6...61tlinx135.png
Are you guys tweaking anything else besides vCore and Internal PLL overvoltage for the 5GHz OCs?
Have found abit lower CPU PLL helps say 1.75v!
Got a L042b291 2500k from Oc Microcenter with the Asus Pro but still waiting on my Noctua from Amazon and ram from Newegg. Search the net and nobody has this batch.
WOW nice, you on water?
Glad to help!Hope everything goes well! Have found memory plays a key part 2!
I got my i5 2500k yesterday with the same batch as Alex-Ro and it is very nice! :D 5ghz stable ~1.33-1.34v and benchstable at 5.1ghz same volt, will try to lower the pll and see how it goes. Could I lower the pll to say 1.6v ? Is it just dangerous to raise it?
awesome Bro!
2500K from MicroCenter in St. Louis Park, MN
Asus P8P67 Pro
L040B671
4.9GHz full LinX stable 1.392v load
nice tool, you should be hitting around 1.4 @ 5ghz seems like its the average with most Sb chips.. Anyone got 5.0ghz under 1.35 ?
What run does it usually crash at?? Try 1.35 ht off ? u using 4c/8t?
I prefer using 4c/8t am happy at 5Ghz 1.35v! Am testing 5.1Ghz 1.35v now! Run 14 Hard lock up! Notice thou on my 2600k that 1.65V Cpu Vtt Help ocing! Have got some new memory coming at the weekend hopefully that could help! 4GB G.Skill DDR3 PC3-17600 Cas7 2200MHz RipjawsX!
You dont have to run your memory that high though, thats whats causing your huge amounts of VTT, 1.65 is way to much dude imo.. 5.1 @ 1.35 is very nice one of the best i've seen imo, if its locking up bump voltage up a bit more.. i can see it stablizing very soon..
Cpu Vtt undervolted at 1.65v intel spec it to be 1.80v Default!
Wow 1.65v? Dinos board had no where near that vtt..
:shakes: no way that's average mate. Keep in mind that the ones listed here are usually the good ones... most inferior results will NOT see the daylight on this forum
I need 1.52Vcore for 5ghz stability, far too much too my liking... benches 3D at 5.2 at the same volts
It's probably PLL(not Vtt).
