wow sargantas nice build! Those Virus reservoirs have different LED switches ???
nah I won't add ports, doubt that it would look nice.
the color depends on the plexi window. the red glowing is with red plexi, the other one with black tinted plexi.
Nice pics :up:
I don't think so that I will make USB/Audio connectors in the front.
Kind Regards
can you contact me with price and info to 90221? Thanks.
Also, you think you could incorporate 10 pci slots on the case, theres only 9. Y'know 4 way sli, just in case... lol
4way sli works, just get a single slot plate for the last gpu and you are fine, no need to change the case.
New computer Feet / Stands available.
- 4 x FI 30mm legs/feet 10mm high with M4 thread made of ALU.
- 4 x M4 screws
- 4 x self taped filz
http://ld-phasechange.com/images/Lit...ses/Legs/1.JPG
http://ld-phasechange.com/images/Lit...ses/Legs/3.JPG
http://ld-phasechange.com/images/Lit...ses/Legs/2.JPG
People who got this case should start posting pics of their setup !!! :shakes:
I would buy one if I have enough money :(
well alrdy posted 3 different cases/systems ^^
I sold some of my flesh and my soul to be able to buy one !! :cool:
More, I just wanna see more ! I can't get enough, I mean this case with all those beautiful systems....it's like the :banana::banana::banana::banana: of cases !!! :ROTF:
Guys. Cases are going to post tomorrow morning. Sorry about little delay, but I was waiting boxes for shipping. =)
Kind Regards
Great, I can't wait to get mine :yepp:
within 2 weeks my build will be fully done. And then ill post alot more pictures.
I'll be receiving my new toyz to upgrade my current systems on Saturday, the only thing is missing is my LD V8 case :(
All orders are shipped. =)
And another nice combination.
http://ld-phasechange.com/images/Lit...lackblue/1.JPG
http://ld-phasechange.com/images/Lit...lackblue/2.JPG
http://ld-phasechange.com/images/Lit...lackblue/3.JPG
Kind Regards
Wow, it's just Amazing :eek: Why haven't I ordered the blue why :hitself:
Yes, It is really nice. :up:
http://ld-phasechange.com/images/Lit...lackblue/5.JPG
http://ld-phasechange.com/images/Lit...lackblue/6.JPG
Kind Regards
^Just incredible!
You have PM btw!
LittleDevil's PC-V8 > TJ07
Completely my opinion, but I know there are some that agree with me. The simple, but powerful look to this case makes me drool.
LittleDevil: what do you think of changing radstands in bottom compartment to something like these (or these) from XSPC? (Probably just one set would be enough though, with dual set of holes in it, for both 120mm and 140mm rads)
- with such that can be mounted wider apart or closer to each other, any rad, no matter what fan spacing it has, can be mounted;
- one/same set will do for rad of any length from single section to quad sections (might lessen manufacturing costs as no need to make radstands for different length of rads, same stands will do for all of them, and no problems with unused "section" sticking out with smaller rads used);
- less important, but nevertheless - less material used/less area to paint/smaller weight - probably will chip tiny bit from prices of making/painting/shipping.
Thanks guys :up:
I don't see why that would be better.
There is much more holes needed in the bottom aera to prepare it for 240, 360 and 480mm rads. With radstand which is now included you can mount any rad you want with standard fan spacing. 140mm rads don't fit inside, because if you use 4 - 140 you can't install PSU and also perforation is bottom side panels are for 120mm fans/rads.
Price if I want to make 4 peaces like you show will cost more than those 2 holders, because each of those 4 needs to have 2 nuts installed, so total 8 and also no difference in painting and weight. :)
Kind Regards
hey littledevil, any chance these can fit 2x 560 rads?
Definitely a great case. But like I told you. I'm still unsure what to do. Either this or the SS version. I'll wait for Bulldozer I think. If Bulldozer is a killer overclocker SS is for sure more interesting. Otherwise I'll go with a dual G34 socket which will fit in there quite nicely..
Brilliant case
