Gimme a little time and I'll take that 1st place for a X4 off Infrareds hands :D
Guess i'll find out if AVG and Asus probe are keeping me back on the score this evening.
Yeah, that did the trick.
http://img695.imageshack.us/img695/7588/r1154b.jpg
Well everyone's only posting up Thubans here anymore but I've been playing with my 965 some more after installing my Mugen 2 last night. Seems I have a bum core #2 when going for 4Ghz and above. It fails almost instantly under load. I'll keep playing with and maybe try AOD as the other 3 cores seem stable.
http://img.photobucket.com/albums/v3...h38Ghz_s-1.jpg
http://farm5.static.flickr.com/4086/...348ddaf8_b.jpg
im liking this thuban x6 :p
any tips? this is on air
for benching you can probably squeeze some more cpu-nb speed. maybe around 2950mhz with around 1.4v on cpu-nb.. more tweaking you might be able to get some more cpu mhz too :)
AMD x4 970 BE, aircooled CM Hyper 212 1028 DPMW
http://img51.imageshack.us/img51/467...64bit4071m.jpg
Is that all your 970 X4 can do? :confused:
maybe more, but i have only 1 try :)...Stress by time :). Thinbk, with normal ambients its in 64-bit TOP at 4100-4120 MHz, with colder air maybe 4200 MHz.
OMG I cry every day for selling my 955 c3, it was prime stable at 4150mhz / 1.50v @ TRUE 120
4150 stable Deneb with aircooling is very impressive! Dont seen much so good Denebs, every 4100 MHz stable Deneb is awesome!
Hi guys, :D
This is my result. 4 processors. I run cinebench through vnc so i think there is much room for improvement left.
http://shots.gr/up/e15af4d716f57e668b8933afce797db1.JPG
You can see the internals of the beast here: http://www.outofspecs.gr/forum/showt...6174-inside%29
that is suppose to be 48 cores right?
yes, dont look what cinebench says.
does it actually try to run 48 threads at once (you would see 48 boxes being rendered at once)
a screenshot of that would be really cool to see.
It should, according to Maxon.... CINEBENCH can measure systems with up to 64 processor threads.
http://www.maxon.net/downloads/cineb...bench-115.html
I'm running single channel ram right now but I did a 7.07 with 4.2ghz and 3.2ghz NB 1600mhz ram 9-9-9-24(40) cheap ram keeping my score low :/ ?
single cannel si bad, timings RAM, what HT clock?
Quick test 445 unlock to B45@4290 MHz on air
http://comelteh.hit.bg/445/c4290.JPG
Update: 8.11
http://b.imagehost.org/0947/cinebench-4_53.png
And just for fun @2cores. I'm sure it can go higher and also there's more headroom on the CPU-NB.
RAM timings could be optimized as well.
http://b.imagehost.org/0638/cinebench-2c.png
I.nfraR.ed:.... Bastage! :D
Are you using that cold Bulgarian air to help your WC rig?
8.11 is a killer score man... :up:
I haven't tried using the weather to my advantage yet, but I've also never broken the 8.xx barrier...
I used the opened window just to cool the room, but it was not very cold: 17 degrees in my room. Well, I had to drop the temperature down, 24 degrees is not good for benching :)
I probably could go higher with more cold and if I put the rig next to the window, but it's too complicated to do it at this stage.
Nice one Ivan, good ram and CPU-NB speed too. I think i have to do some catching up. :D
