I canceled the cpu. My CPU now make 4Ghz and will make 4,1Ghz with air-cooling. I will search 4,3-4,4GHZ full stable on 965 C3 if anyone know what stepping CPU i will have to search. I would be very grateful. :(
When you found it give me a call, i would like one too.
It depends on what you're after mate, my cpu can do 4.2GHz pretty easy on 1.48V but it reboots after a few minutes of Prime blend.
I could use it for webbrowsing and email and stuff like that though. I decided to back down some and run it at 4.1GHz which is Prime blend stable at 1.46V.
I "remodel" DVD and Blu-Ray and because that 30minute prime blend is prefer for stable system :)
sometimes newhere about my C3 AIR
idling at 4500MHz :D
http://img13.imageshack.us/img13/8071/4500mhz.png
nice one FlanK3r :up:
what was the cpu voltage?
CPU-z say 1.55, or do u mean what bios says?
Dragon
nope, I mean cpu vddc in aod
Cinebench x86 13 456points
http://img94.imageshack.us/img94/478...160mhz2842.png
3D mark 2006 with default clocks HD5770
http://img692.imageshack.us/img692/3...9mhz2717mh.png
And :up: superpi 1M under 16s, uff :) 15.859s
http://img692.imageshack.us/img692/3...mhz3000mhz.png
I got 0944FPMW here, will slap it with single stage. I hope it will clock good
Edit: Here we go
@ -12C in bios
ACC auto
Unleashed mode enabled
http://img192.imageshack.us/img192/6...eenshot481.jpg
With a little bit more cold, 5Ghz+ and NB @3.5G is possible with this 0944FPMW
Well since I was not able to crossfire the 5770 and 5850, here is a single 5850 run at 4.3ghz
Phenom 965BE C3 4.3ghz/2400NB
8GB DDR3
5850 single 775/1100
Win 7 64bit
Cat 9.11
= Compare link =
http://3800z24.info/Phenom/965/5850-4.3ghz-965-3d06.jpg
mind running it on win7 64bit with settings as close as you can get to these (comparing it to my 4870x2):
http://i70.photobucket.com/albums/i8...5htthighnb.jpg
Nice one Charged!! my stock 06 run with my 5770 was 16,293 (memory at 1300 cas 9-9-9) as that it is what it set stock, just changed them to 1600 6-6-6 and did a burn in for my TIM, letting it set for a few atm, but ill have a few worthwhile posts in this thread here in a little bit lol
Dragon
http://img194.imageshack.us/img194/1...nshot004fl.png
A Dirty run with $2 silicone TIM and my 955 settings:shrug:
Looking forward to the post. Right now I am running a vantage run. i will try out afterburn to see if I can OC it more, not sure since 775 is CCC limit.
Edit: here is my Vantage run. These are not optimized results, I will try those later. I am in a hurry tonight lol.
= Compare Link =
4.3ghz 965BE C3 2400NB
5850 775/1100
Win 7 64bit
http://3800z24.info/Phenom/965/Vanta...850-single.jpg
My first test runs with new kit of RAM, so still shaking this down.
http://img685.imageshack.us/img685/5...0mhz665870.jpg
Hey Crazydiamond, were you asking me? I can if you want, I would just need to increase my NB and set the mem a lil lower. I was in Win 7 64bit on that run. If you were not asking me then safely ignore this post LOL :p:
That was a nice run. What RAM you using there?
I will.
ACC disabled
Vcore @ 1.675 in bios
-9C idle cpu temp. in bios
This old single stage crying to uphold the load
http://img33.imageshack.us/img33/572...enshot485s.jpg
