No, just hopeing for more stability:)Quote:
Originally posted by NapalmV5
Good contact = 3400 ? 3500 ?
OPP
OPP
Here you go Opp, a peek at my condensation proofing pulled back. I took these while broken down.
The hole, this is a 2 layer 1" thick faom stack (1 layer present to show you more detail) The top lexan screws down flush with the top of the block enabling the C clamp perfect positioning on the CPU with no worry of getting it wrong.
http://fugger.netfirms.com/foam1.jpg
Here is another shot with the block in place (top foam missing) and you can see with enough pressure there will be no moisture around the base of the CPU socket.
http://fugger.netfirms.com/foam2.jpg
1" foam on backside of motherboard.
I hope this helps some, works great for me and it is easy to break down and rebuild quickly. I went through 2 rolls of foam tape before I figured out that building up a foam box after I set the evap head was not working out.
hehe...Quote:
OPP
Wow, another 200MHz more should get you very close to 31K, if not 31K. Good luck, OPP.
FUGGER,
Looking at the pics, how do you attach the top foam ?
FUGGER,
LOL!, just noticed your avatar, every time i see your avatar you got a different refrigerant, last time R507, looks like R508 got you lower temp. So, when you're gonna go for R6XXx, R7XXx ?
The second layer is compressed under the lexan like in the image. The top layer is foam taped on.
Version 2 should be done by Thursday if all goes well.
ah.. sneaky fugger 8-)
The FX goes to the Top of the 3D03 charts.
OPP
:toast: :D
Is there no stopping this man :confused:
:D :banana: :toast:
Yeah...
that's pretty sick :D
C
Just for argument...
about what score would fugger's system get in 3D03 with xt clocks like opp's (614/465)?
Probably gonna find out this weekend.........................Hey OP what GPU cooler U using....
Chilly1,
Just a heads up to you guys:
With mine I used all the way up to 2.21V to get 613 stable through Car Low. So don't be too afraid of big voltage, I didn't see an improvement with memory overclocks with Mem Voltage up to 3V. Hopefully with your mem cooler you may see a result.
I could only do 594ish at 2.0V... like a lot of the guys run.
C
I'm useing a basic Promy MachI that has 404A and a Baker 9800 block on it. I believe Baker made it. Very nice cooler:)Quote:
I'm useing the Promy MachI that you fixed on the CPU, nice job:)
OPP
hm... lets see some 614/465 + FX-51 @ 3.2+ghz. action in 3dmark2k1. ;)
im thinking 31.5k? at the very least... ;)
or maybe he already has that high a score, but is just waiting for others to catch up. ;)
I wouldnt wait, id just hit them while they are down. waiting months for others to catch up then beating them by 100 marks is a waste and not that impressive, but a 31k run when 2nd place is 2k below you really shows your fame :) and opp's 3.2GHz is super, but is it stable enough for 3dmark? I also notice he had his 30k run at 609 core, hes up to 614 now. 625 core and 3.2GHz could be the 31k run :D
i dont think he needs 625 to reach 31k.
i would think 614/466 (3dmark2k3 run), and 3.2+ghz. also remember, he said he has bad contact, and he had 3.2ghz...
good contact = 3.2ghz stable?
200mhz more on the cpu, 12-15 more on the ram, and 6 more on the vpu, i think that would give him 31k. ;)
im impressed way more by the radeon oc than by the fx oc. 600+ is incredible! almost a 100% oc from the original 9700 pro and its still made with 15µ!
Yeah. Must be an superior-cooling over warm water ;) :DQuote:
I am proud when I can go 525-530 with heavy artifacting while benching :slobber:
and here i thought my 463 on air to bench was good... *sigh* oh well..
I just figuerd out a memory mod for this SK8V mobo. Got this registered ram putting out some overclocks. This makes it a whole new ball game:D
OPP
lookin good OPP. Hoping to see some new compares from you soon:D It's time to squise the last ounce of performance this chip has to offer, i think:)
OPP
hm... more like, last 1/2 a pound... :DQuote:
and opp... curious... whats the cpu tab of that thing say :D 13x250? 13.5? :p:
OPP:
What would 3200MHz, with 250 1:1 and 614/466 give you in 2k1?
