PCMARK05 - 2D Transparent Window
Originally Posted by
Hondacity
try re-inserting it into the pcie slot...i get errors when i do it wrong...
Got it up and running at 850/950Mhz, dunno if I can go more on air.
My problem is the 2D Transparent Windows test result if WAY OFF, by 9,000 points!
What can I do to correct this (all the other tests were fine).
EDIT: Could it be the card reseting clocks to 500Mhz on 2D?
Help with low 2D Transparent Windows - PCMark05
Hondacity
Excellent that you have it running:)
yes 2d down clocks I don't know solution sorry, we will have to research on it
team.xs
Mind sharing info thanks
I remember now don't disable aero!!!!!!! :)
Well I can't even change the Visual Settings because when I do PCMark says it won't run! So I have to leave it on Maximum Detail... Anybody knows the workaround to this and which options to choose?
Well it is definitely a setting that I'm missing, I did 21.5K on my first run with 3,700 2D Transparent Windows points and everybody with less hardware get way over 10,000 points on that.
I'm using Catalyst 9.8 from TweakForce and I did find an option over CCC_3D to disable 2D clocks (didn't seam to help at all).
