Hello Sky, Jamal is my name;) My kind g/f posted some links for the r3603 as you have seen. Yea I'm familar with the mh2075 and wouldn't mind trying it but I think it would be overkill for our application and a bit expensive.the mh 2075 is for much stronger chemicals like methyl- ethyl-ketones , xylenes and such.I work with these solvents every day and know their properties first hand. The r3603 has excellent resistance to milder chemicals such as methanol as you have stated. I have had my r3603 in my coolant for over a month and see no signs of degrading .Quote:
Originally posted by sky
@jamal
i hope you don't mind me shortening your nick ;).
i've been looking into tygon r3603 last week and they sell it only in 15 meter rolls for about 86 euros. that's way more than i need - and on browsing the pages of ismatec sa (tygon factory guys) i found something that bothers me. in the specs they say r3603 incorporates softeners (don't know if that's the correct term) and is basically yet another pvc-mixture. and it is said that r3603 isn't recommended for use with solvents - solvents here referring to stuff as in paint, etc.
that's why i started to worry about you running paint thinner or similar stuff through it.
it should be ok for alcohols or similar stuff, but i spent some more time at their site and browsed for other materials and found tygon mh 2075. that doesn't incorporate softeners and is resistant to solvents of any type. the temp-range is given as -70°C to +52°C (not exactly my range...). so now i'm trying to find a reseller that lists this. so far i only found about 4 shops in all of germany (!) that offer r3603 - and those are mostly medical equipment suppliers, just as you said.
anyway. my windshield solvent test wasn't as successful as i hoped. temps went to about -10°C since that stuff started slushing. i had the chiller run for some time and had to do other stuff, when i returned i had a fat piece of ice in my rez - doh. so that mixture was crap and it stinks pretty bad. i didn't have enough of it (and if i had i would have been woozy all day) and had to add water - too much it would seem ;)
so next up is the test with real car-coolant - that should give me an idea of what temps can be reached.
btw happy new year from 2004 already :D
Yea , I wouldn't add any water to the coolant just a mixture of engine coolant and methanol. Equal parts or a bit heavy on the methanol side works best for me, and yea it produces a vapor that is unpleasant and not to healthy :slobber: Make your cover, but you really should insulate it .
