Glad to help, make sure you keep an eye on temps though. The extra cpu-nb adds heat to the cpu. I know it's Winter for you down under but I'm sure it's still fairly warm.
Wow that is pretty cold. We average around 0-3C during the day in the winter months, but I didn't expect it to be that cold in Australia. Off topic but you're probably higher elevation right?
The advantage to nb clocks is that your L3 cache runs at this speed. Better overall performance since the cpu cores aren't waiting around as long for data I'd assume. I'm in Massachusetts, USA elvation about 30m above sea level. I'd heard the average temp in Australia during the winter was about 55F(13C).
Higher NB results in more memory bandwidth. Test with everest and you'll see the difference with each tweak.
Didn't take a note of my stepping, and I cbs taking off my heatsink atm. I'll repost when I do though. Was an easy unlock, only had to turn on ACC. Stable on ~13h P95.
KayDat - GA MA790GP UD4H - F3a - Success
http://i76.photobucket.com/albums/j1...quadstable.png
Haven't gotten around to overclocking yet though.
anyone had try unlock proc 550 BE with mobo intergrated 780G Ultra chipset?
Pretty sure you can't with a 780G, since you need a SB750 or SB710 southbridge. I started off with a GA-MA780G-UD3H, and I changed it for my current board, so I could try unlocking my CPU.
What is the max safe voltage for these chips 24/7? Right now I'm running 3.9ghz @ 1.5v and 4 cores (under load it drops to 1.488v.) Prime95 stable for over 5 hours, which is good enough for me.
http://img38.imageshack.us/img38/6343/bigoc.th.jpg
0922CPMW - [xc] flat-four - GA MA790XT UD4P - F4 - Success
Hybrid/Auto -2%
No overclocking yet.
http://i32.tinypic.com/hskwgm.jpg
>24h stable on P95. I'll get to overclocking mine eventually.
Success!
http://pctuning.tyden.cz/ilustrace3/...2_x2_550_2.jpg
http://pctuning.tyden.cz/images/stories/DSC00908.jpg
http://pctuning.tyden.cz/images/stor..._oc_unlock.png
Board Asus CrossHire III, last BIOS 0403 ... look at new menu Unleashed Mode ...
But, my two cores are very bad, i cannot to OC them above 3,4 GHz ... at any voltage.
0921APMW - Cele303 - Asrock A790GXH/128M - P1.20 - Success - Link
ACC - Auto
http://img31.imageshack.us/img31/3207/550x4.th.jpg
Update:
0918BPMW - Cele303 - Asrock A790GXH/128M - P1.20 - Success - Link
Wohoho look who is here,my old mate Cele303,you have the same batch like me :)
Hi Guys,
I got the 2 sealed cpus: 0920gpmw and 0921apmw to put on a new and also boxed biostar TA790GX 128M
Which one should I keep? Neither of the steppings seems very successfull unlocking :shrug:
0922APMW - PowerSlide - Asus M4A78T-E - 1503 - SUCCESS
http://img.photobucket.com/albums/v3...de/550BEX4.jpg
This might of been asked before.
But how does one check the temps? Real temp can't even be open while Core Temp have a ? on it :(
I took delivery of a Gigabyte GA-MA790X-UD4P Motherboard on Friday so I've been having a play with it and my Phenom II X2 550 after flashing it to the latest Bios thanks to it running an old F2 version!
I purchased the CPU about a month ago and its a 0919EPMW Stepping and had 3.8Ghz in my old Asus M3A32-MVP DELUXE/WIFI-AP Motherboard as a dully.
On the Gigabyte however Its now a SUCCESSFULLY UNLOCKED QUAD :D
http://www.michaelscomputers.co.uk/p...IIB50stock.jpg
I've been playing ever since and managed to get 3.6GHz nice and stable:
http://www.michaelscomputers.co.uk/p...IB503.6GHz.jpg
To say I'm happy would be an understatement :) I'm having some issues with getting it to 3.7GHz as a Quad with Blue Screens & Reboots but still playing with bios settings! I'm more than happy with 3.6GHz but playing around is fun :) . The load temps are about 55deg running as a Quad 3.6GHz also, they do go up fairly rapidly when I use more volts though.
So please add me to the list:
0919EPMW - gamesaregood - GA-MA790X-UD4P - F5 - SUCCESS - :D
Im glad to see you flashed to the F5:up:
Lots of people that could not unlock these chips were using F2 or F4 Bios which is by all means buggy as hell.
Even when i first installed my 550 i flashed to F5a beta before even testing the Stock F2/F4 bioses.
Once i saw people were having problems tweaking the Bioses i flashed to the Older ones and experianced thier Problems.
To Date the F5 is the Most reliable Bios for ALL AMD chips on UD4P.
Ive tested and played with all Volt settings with a 9950/720/1640/550/6000+ cpu's. and the F5 handles em all.
So if anyone is trying to UNLOCK 550's please use the Most recent Bios for Your Mobo.
It will save you AMDheartheadache , if you update teh Bios from the Get go:D
Phenom II 550BE 0921FPMW
Motherboard: ASRock A780GMH/128M
latest bios 1.20
Just black screen with any ACC settings other than default.
