pm sent:)
hehe, tell me about it! I have the shakes and stuffed mine...
Hopefully they can fix it for me with the RMA, if not I will just buy another one or wait and see if the ex58a models will be released.
A quick question, would there be anyway of just using wiring and a hot glue gun to attach the wire to the solder points on the board then soldering the resistor to the actual wire?
Just trying to think of a more 'safe' way of doing it for next time.
Thanks for the e-mail hicookie ;)
I was wondering, could you just solder another resistor into the space, or do you have to move the one from the board?
Cookie can you send me the mod instructions and bios please? :D
I am not sure about Hot glue, I think that would not work. But you can solder wires then attach a resistor. I have seen it done here >>
http://forums.overclockers.com.au/sh...d.php?t=789406
It could be any 1K ohm resistor, I found many 0402 exact ones on eBay if you wanted a exact replacement, but I think any would do if you connect it properly as seen in the above link
Thanks for that. I wasn't too sure if it would work or not but worth a shot.
Apparently my board has been sent overseas to Gigabyte according to the place I purchased it from...
Would you know anyone that works in the RMA section hicookie that could be able to repair at my cost?
Hi all.
hicookie, can you send me PM hard mod instructions/pics for the Ex58 Extreme
thanks
sorry for my bad english
Hope you guys don't mind me jumping in here.......
Bear with me this is my first few hours on an i7 rig....this is the max I can pull on stock cooler.
Modding board tommorow.
I noticed someone mentioned PCI E frequency? this is 104 PCI E.....no mod.....you have to boot 100 then reboot 101 then reboot......baby steps. No diff then my AMD giga ;)
here's a couple before mod shots.
http://chew.ln2cooling.com/qdig-file...rg_playing.JPG
http://chew.ln2cooling.com/qdig-file...laying%202.JPG
good work
very nicely done for your first session on new gear :up:
hey dinos22
do you have the pci mod? :D chew and i need em :D
you'll need to ask hicookie
he's the man heh
I just got an email from Gigabyte about my board.
$80 to fix
:D
Cannot wait to get it back!!!
Thanks for the PM to you know who :)
MOTHER FUKCER...those are so fukcking small..
hey [200] was that done in gigabyte usa?
hello guys!
I have problem with oc-ing my UD5, i7 920 D0 + TRUE, both lapped and OCZ 3x1GB 1600MHz Intel XMP LV.
There's no way to push bclk above 200MHz, no matter what i do. it just freezes at post screen or it won't boot at all. i crossflashed ud5 with EXm bios from page 4, but no luck, same problem. when i set pcie clock 105 or higher it also won't post with "6F" message on diag. gpu is ga 8800gts 512MB and psu ga odin pro 800w :)
PS I know my english sucks
enyone?
High IOH voltage can help push things as well demios, so try 1.3-1.4+ and see what you can get.
But as hicookie said it may be your CPU, if you can't do 222 without the mod then the mod wont really help. You need a good CPU to start with, before you even need to mod things
tnx guys, but no luck. 1.3v+ for IOH results in no post, or freezing the screen in win when using ET6
it looks like cpu has bclk wall :( so I'll ask my friend to bring me his D0 which works fine on 215 bclk on MSI x58 Pro E
but strange thing is that i owned C0 rev of cpu + also UD5 (not the same sample) and had the same problem. 200MHz works like a charm, but anything above...
My MoBo work 226 & 102 pci-e
228 & 103 pci-e
i swapped ud5 and d0 for ud3r rev 1.6 and another D0, and solved my problems, for now stable bclk is 225, pcie 103, me happy :)
Hello friends is a pleasure to share with you much I love this forum I now have X58 platform. But I'm stuck with bclk I failed to overcome the barrier of 222. Via air and reaches the ceiling, I'm ready to get started with extreme cooling with dry ice, I'm studying such as Isola besides plaque components using
Gigabyte Extreme X58 + I7 920
http://www.pctunerup.com/up/results/...06_2009091.JPG
http://www.pctunerup.com/up/results/...59_2009071.JPG
http://www.pctunerup.com/up/results/...285A810MHZ.JPG
Rampage Extreme X48 + E8500
http://www.pctunerup.com/up/results/...25_2028E71.JPG
