You can ask him if you want to: Link to thread, see post #13 He had been using it prior to going to the S60Z and he had issues with the S60Z and got EVGA to send him that S60V BIOS file again.
You can add the S60V BIOS to your front page from this post: http://www.xtremesystems.org/Forums/...&postcount=248
Can you PM me so I can email you the S60H BIOS?
Hey guys quick question Iam using the 1200watt silverston Zeus which i switched to single rail...Since this pwrspply does have the extra 8 pin pwr(which means plugging in both 8pins) should I go ahead and use it..Any drawbacks from using it...thanks..Kind of needing a quick answer on this fixing to boot for the first time in the case and with water...
The S60M bios is the one that come originally with the board, right?
I don't have problems with S60Z but i might downgrade to S60M... since S60Z is a beta BIOs...
There has been no problems whatsoever with me using the beta straight off the bat for me. Even though its beta its works like a charm.
thinking of getting this board
my requirement is that i need a free pcie 8x slot that WOUNT be under my 2 gtx 280's bridge can i run sli in slot 2 and 4 or 2 and 3??
thanks
Another BIOS released: EVGA X58 Classified (E760/E761) - S610 BIOS Released
This BIOS is ONLY for the EVGA X58 SLI Classified Motherboard (part number 141-BL-E760-XX or 141-BL-E761-XX)
S610 Updates:
Improves support for Intel Xeon CPU's
Fixes Smart Fan S3 Resume
Adds additional option for QPI Signal
S3 Resume Improvements
Little bit Prime :)
http://www.abload.de/img/image43qtob.jpg
Wow, nice clock and nice temps. What is the batch # on that chip?
Thx,Batch is 3845A935.
I7 950 D0 ES 3843A
eVGA Classified 759
3x1go D9JNL at 2v
Zotac 285 GTX
LN2 at -95°
Vcore 1.5/1.54v
http://valid.canardpc.com/cache/screenshot/586085.png
http://valid.canardpc.com/show_oc.php?id=586085
Update today (pb cpuz validation)
http://valid.canardpc.com/cache/screenshot/586882.png
http://valid.canardpc.com/show_oc.php?id=586882
A few days late but TO should update the OP with a link for the new S21T BIOS for the 759 Classified...
ftp://ftp.evga.com/bios/E759S21T.bin
Can you guys be honest with me; Is it worth for me to upgrade from my P6T Deluxe to this? I am honestly considering it but am not too sure.. I will be doing Quad-SLi, not TRI-Sli.
Thanks!
I havent read many good things about the p6t so yes
is $400 after rebate a good price to pay for it?
Not really, I don't know maybe prices are going up but I payed $385 for mine no rebates. I am using the 760 version without the NF200. You should be able to find this for 400 bucks without any rebates though. The 759 version is discontinued if that is what your looking at. Without getting into any arguments I highly recommend the 760 version over the 759, especially if you are going to Quad SLi :)
Cheers
