R3D: Now that we've started touching sensitive topics, can we find out what's up with the interconnect? Why is it disabled? Are naysayers correct in stating that it's up to the AIB whether or not the traces for it get built into the PCB, and that it's likely to not be enabled?
Eric: The sideport interconnect is fully functional in the reference design. Though we've found that with the current AFR mode of multi-GPU support, the additional bandwidth brought by the interconnect does not translate to a significant improvement in performance. However, we are continuously working on optimizing how our ATI CrossFireX™ technology scales and trying different methods, and could decide to enable the sideport if a method is found which gives better results and benefits from it.
R3D: So what happened? How did a good idea stop being a good idea? Are you disabling it due to heat/power concerns?
Eric: It's still a good idea...you have to consider that we've been working on Crossfire and on our AFR implementation for quite a few years, optimizing it. It's actually gotten to a point where it's really quite good, and difficult to improve upon performance-wise. As for heat and power concerns, that's hardly the case...the interconnect is pretty much an extra PCIE2.0 link. The power draw for that is in the realm of a few watts at most. The only reason for which it's not enabled currently is, as I've already mentioned, that it does not significantly impact performance ... and if you're not using something there's no point in enabling it.
