Originally Posted by
alpha754293
Just so you know, your intepretation of the results is inaccurate/incorrect.
The actual benchmark results is SAPS.
And there are a number of things that I find a bit interesting about this benchmark result (both of them done by IBM, albeit at different facilities).
For the Nehalem Xeon (X5570), it's 8.5% faster in clock speed compared to the Opteron 8384, but the Opteron system has more memory than the Xeon.
According to SAP, a (benchmark) user is defined as "A simulated user that runs the specific dialog benchmark scenario in a loop, repeating the actions with a think time of 10 seconds between each user interaction.".
In terms of SAPS/user, the Opteron system is 0.2% faster at 5.015 SAPS/user while the Xeon is at 5.005 SAPS/user.
Also another interesting thing is that the CPU utilization of the Opteron system wasn't as high as the Xeon (95% vs. 99%), which would tend to indicate that either a) it could have supported more users (I haven't been able to find out HOW they get that number actually), or b) that the Opteron is completing the transactions/requests/operations for the benchmark in less than one full second.
MY guess is that either it means that IBM wanted to achieve similiar SAPS by reducing the number of users (which seems likely given the "odd" number), and that the slight performance advantage (0.2%, and a 95% CPU utilization) could be brought on by the memory (architecture and amount).
IF the SAPS/user is correct, then for the Opteron system, my projected SAPS for 5100 users would be 25581 which would only be 51 points higher than the Xeon.
It's interesting.
(I will also like to add however, that given that one's a 2P/8C/16T configuration and the other's a 4P/16C/16T configuration, that the initial cost might be able to the same for both systems, and that I'd also expect the power consumption to be about the same as well.)
So, to those that are saying/thinking that the Core i7/Nehalem is an Opteron killer...at least for this benchmark...not quite.
(There's more to the benchmark than just the SAPS number. Because if it were ONLY just the SAPS number, than the Sun/Fujitsu-Siemens SPARC Enterprise Server M9000 is your baby at 195,000+ SAPS. THAT would blow anything/everything out of the water with 64P/256C/512T and 1 TB of RAM.) And even then, it's CPU utilization is only a measily 67%.
