Hi
Gligy
i will also have to use the method shown above to connect the waterblock
have purchase oem CPU part by mistake
SLBCH costa Rica
3835A766
will have very similiar setup to you
Gig byte UD5 & 920 cpu D_tek fuzion V1 with accelarator jets
have you install the jets
how are your temps for the (North / south bridge)
is there any settings you have found that help the overclocking
what uncore, dram volts & are you using
cheers
mark
