Originally Posted by
RASTAVIPER
I still can't understand why this mobo doesn't help the OC with higher voltages.
Cpu can't get 1 single fsb, even if I try with VCORE from 1,45-1,65.
Ram can't pass superpi, even if I try VDIMM from 1,90 till 2,1.Or with lighter timings..
OC doesn't get better even if I increase the NB VOLTAGE.
All previous are main factors that all other AMD chipsets (NF2,NF4) had and helped a lot with OC.You weren't stable at games?You increased the Vcore and NB voltage and you were fine.
Couldn't pass SuperPi?Increased the Vdimm and then ok.
I believe we need some serious BIOS
