i would say you're at 1.33 because of your clocks
Found it. 1.28 idle, 1.33 ish load ;) ... going through 3D03 now.....
that's even better than my core
what kind of cooler do you have on that card
Full stock.
Asus 8600 GT 512mb DDR3 silent.
http://images.google.ca/images?hl=en...-8&sa=N&tab=wi
~62c loaded at those clocks with ~25c ambient and a single low rpm 80mm pointed at the heatsink......
edit - 3d03 numbers.
ah ok
nice cooler
http://www.tech-hounds.com/review34/...USEN8600GT.jpg
better than my card for sure hehehe
It actually sucks pretty bad ;)
3D03 numbers added btw ;)
edit - and i'm running rivatuner temp monitoring int he background through another run just to see how 3d03 affects temps vs AM3.
edit - awesome, my CRT caught fire :D
Yes.
I guess 1024x768 @ 100hz was too much for it with a box on top :ROTF:
Its still working fine though. Took the box off and used a box fan to whisk the magical smoke out the door. Re-ran 3d03, +300 points.
64c through 3d03. Changed fans now though so -1 or 2 c maybe from 64 if I reran.
i usually read from caps after the inductor for whatever voltage...
my card is bytching out at 1.74v :(
single stage cooled
don't know if contact was good or not
this blows
MASSIVELY BOTTLENECKED by RAM speed
so the faster the ram the better the scores will be fellas
core speed really means very little once again
weird
i can bench nature with say 700MHz core linked 850MHz RAM with 1.9v to the core
yet if i bump it to 800MHz it crashed WTF
Sounds like the 8800GT's where GDDR3-2200 was possible with stock cores but 800MHz cores made GDDR3-2000 a fight.
yeah but you could still clock the core by lowering RAM
this is different
i have the same exact card.. stock sink and a 120mm fan @ 100cfm, 1.6v 972 mhz core and it does not hit 60c... going to remove the sink here soon and toss the chiller on her.... only thing is now i think i am at the power circuit limit.. since no matter what i do now i get the instant line artifacts when i change to anything above 972 mhz.. even with 1.8v...
and again the mem is :(
anyone know if all these cards are cold bugged?
happy modding!!!
how many volts are u running dino? and 945mhz the max u can do?
Possible that the core is exhibiting a coldbug like the 8800GT and the 9600GT? Perhaps try naked die without TIM and see if the warmer core helps.
Card arrived today. I'll see what I can do on air tonight on my e8600 rig.
maybe mount it on phase or something?
I'm getting around to doing my vmods sometime this week ;)
