Yes, I can with more vnb, and vref;)
NB~1,594v-1,601v
NBvref : +12,5mW
DDR3 A vref : +12,5mW
DDR3 B vref: +12,5mW
RAM~2,183v-2,196v
2000 7-6-6-18 1T SPi 32M done
http://img396.imageshack.us/img396/3...41601vrtf6.jpg
NB~1,594v-1,601v
NBvref : +12,5mW
RAM~2,183v-2,196v
the gts kit is not bad neither, but you really have a sweet board to let them shine
available anywhere in the usa?
not yet, but i know there is being worked on that case
OMG over@locker886 show us everest benchmarks!!! :D
When are this coming to US!!!!!!!!!!!!!!!!!!!!!!
@Kasparz : are you shipping in asia? possible s'pore?
coz i'm live in indonesia
In Portugal where i can get 2x2gb diablo 2000mhz???
Mine got in this afternoon-- GTR. :(
Running 900 7-6-5-18 atm, 32M stable with 2.05V, haven't tried higher but will tonight.
Now I can bench my D9GTR kit @ 2000 7-6-6-18-1T with 2.2v till SPI 2M at 4M I got an error in a bound
Maybe some tweaking could help but I don't have the vref option in my premium bios :shrug:
what nb voltages are you using tomati?
I give up at 1.67v, I have a 120 mm fan over it but don't like so much voltage on NB .
I even tried to relaxing the PL till to 10 but gain nothing ( error or freeze)
I'm able to run stable at 4000ghz ( 7 * 571) with ram at 1828 cas 7-6-6-18-1T with 2.1v and only 1.49v on NB and 1.2v on VFsb.
I didn't touch the skew as I'm not familiar with so I let them at auto.
Skews will likely help and try higher nb, your playing x48
Lets us know how it goes when pushing further
Wich is better GTR or GTS? I have very good experiences with both of them.
Some improvement but I think I have an heat issue, I was able to pass the 4M with 1.69v on NB but 8M get a freeze, I just push my fan to it's max 1350 rpm instead of 800 rpm ( yate loon 120mm on NB and an other one on the Ram)
1.75v was the max I have tried but my heatpipe was really hot and the 2M allready frozen so I slow it down to 1.71v and still failed in 4M.
Never been able to run the 8M, got freeze before end, I need to try with a powered fan on NB .
tomati, glad you did improve
but wise words is pretesting pretesting pretesting
Go keep pushing it
impressive... i'll take 3 sets...
looks like these will become legendary... anyone able to get hold of these in the uk....
sounds good tomati and the premium is an awesome board for sure, and as told when play 1g+ nb voltage is likely one of the keys
Glad you did it, have you eventually changed paste or maybe going for changing the cooler?
I stopped at 1.83v on NB as I didn't get much improvement (16M failed).
I didn't changed the paste as the heat transfer seems to work fine but maybe should I give it a try.
No cooler replacement as my TRUE wont let me choose other PWM heatsink as I'm running it in Push/Pull.
(Gets a panic attack after seeing these results)
okay tomati, altought swiftech mc14s will go likely anywhere and work quite awesome
I think i found some stabilty now at 600 FSB, just needed 400 strap and plenty of volts on the mem, much more than with lower FSB. :shrug:
The ram is nice though. :)
with higher fsb u will get the performance better, still if memory is running same speed, so common you need higher vdimm, because you will more burden on your memory
