http://www2.basf.us/inorganics/pdfs/...asheet/NaK.pdf
If it is going to react with air, it will react with the moisture in the air, causing a large amount of heat, and hyrdogen gas (which will ignite). It wont simply become "solid" and inert. Also, there IS moisture in the air inside and around computer cases, why do you think insulation is required for subzero cooling? No to mention, it poses a risk if it becomes damaged while being shipped or stored, as it is more likely to come into contact with water (as well as moisture in the air). This is silly, I dont think you really understand the potential danger present with the use of NaK.
