would this work on GSkill DDR3-1600 2gb modules?
I think it don't work with 2gb module(16chips), but work for all of 1gb module(8chips) used micron d9-gtr
aaaah, nuts!:D
these were my 5,5,5,12 settings E8200 3,900 7.5x520Mhz @2.40B 5,5,5,12, but i've not tried pushing them up as far as pushed it quite as high as Venom.
darn, your site is down since early this morning
Yep server upgrade. :DQuote:
hey buddy!...how's life without home plate:D
:rofl: Pretty wierd , started this am with email volume down 50% , got more surreal as day's gone on. Nearly there I think , but am away to bed it's 01:06 here :DQuote:
Pressing Alt + F1 on Memu Page will bring you additional bios option:
CPU GTL Reference VOltage for CPU1 and CPU GTL Reference Voltage for CPU2
I am on Bios F5a. Never try to use Alt+F1 on other bios. Maybe this additional option can be found alos on Bios F4 series??
It's been like that since the x38 m8.Quote:
Gigabyte X38 DQ6
my best understanding:-
X48 & X48T CPU GTLREF
luck:)
i have ram that has died because one module on the stick was bad....it happen with expensive stuff on an excellent board (IP35 Pro)...it was corsair dominators...i had to RMA the sticks...main reason for RAM to die on you is over-juicing the sticks and if you have a weak stick, it is a perfect way of killing the RAM.
i am currently using GSkill DDR3-1600, 2 x 2gb...works well, but i was careful with the voltage...i didn't take it over 2.05v.
this board is excellent!...i would rate it 9 out of 10.
Thks for the input.:up:
But my mobo does not like divider 5:8=(
No matter what I did, it just refused to boot up:mad:
Anyway. Managed to get some CF results on this mobo. Trying to break 20k but my gpu does not play nice on me
3D Mark 06
http://i234.photobucket.com/albums/e...w/19342-06.jpg
3D Mark 05
http://i234.photobucket.com/albums/e...w/29306-05.jpg
AM3
http://i234.photobucket.com/albums/e...iew/270929.jpg
For 3D Mark 03- The higher my cpu clock is, the lower my score will be. Anybody know why??=(
do you have a comparison bench to show?...if you are talking about 200 points or less i would say that is just a variable between benches.Quote:
Originally Posted by memory
BTW, nice clocks!:up:
Nice going memory:up:
i'm lagging a bit behind those scores a bt :lol:
burt am still quiet happy on E8400 4,336 8x542@3.33D 1,807 8,7,6,14
luck:)
@Ace,
The score difference is about 1k. At 4ghz (CPU) my score is around 70k but when my cpu is at 4.5ghz, the score dropped to about 69k. run the benchmark for trice but always get the score about 69k. When down clock the cpu speed to 4ghz. The score jumped from 69k back to 70k again. =( . I don't have the screenie for the 69k run as I am not happy with the score and just don't bother to save it=(
Anyway. This is my best score for 03 run, period
http://i234.photobucket.com/albums/e...w/72190-03.jpg
@supershanks,
Thx m8
Oh something I forgot to mention, Have been running since last sunday with memory in the green slots. I've had no issues at all , perhaps it was the early bios that made the pink ones run better ??
I'm still on F5A
gigabyte X48T-DQ6 new beta bios F5D available for download: http://station-drivers.com/page/giga...a-x48t-dq6.htm
Thanks Ace running omn it now. :) seems olk . Main noticable change is in Menu :lol:
The MIT section has moved from bottom of pagre to top :D
:lol: so have I , it's called dinner :DQuote:
cool!...haven't gotten to flashing as of yet...so much on my plate
That Too!:ROTF:
use this template to flash manually
