Originally Posted by
ash5555
Wow! Thank you for the thorough response. Here is what I have so far...
Question 1: What RAM vendors & models have you tried, and what DIMM positions have you tried?
1x Patriot Extreme Performance 4GB(2 x 2GB) DDR2 800 (PC2 6400) Single Channel Desktop Memory
2x Patriot Extreme Performance 4GB(2 x 2GB) DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
1x G.SKILL 8GB(4 x 2GB)DDR2 800 (PC2 6400) Quad Channel Kit Desktop Memory
2x Crucial Ballistix 4GB(2 x 2GB) DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
Below is a summary of what I've tried in terms of slot population with all brands:
__________________________________________________ __________________________________
Ram Slots Ram Total Results
G G O O
[1][2][3][4]
Y N N N 2GB (single channel mode) =Bios posts, Vista boots and runs fully
Y Y N N 4GB (single channel mode) =Bios posts, Vista boots and runs fully
Y Y Y N 6GB (single channel mode) =Bios posts, Vista Crash Bluescreen
Y Y Y Y 8GB (dual channel mode) =System on, Black screen no video signal
Y N Y N 4GB (dual channel mode) =System on, Black screen no video signal
N Y N Y 4GB (dual channel mode) =System on, Black screen no video signal
Point 2: If you have four DIMMS installed, they should each be running at dual channel speeds. However, if each DIMM is a 2 gig stick, for a total of 8 gigs installed on the board, you might need to bump up the North Bridge voltage to achieve stability. 8 gigs is possible, but as on any desktop motherboard, it can be taxing on the NB. As such, you may need to manually adjust voltages before your system can successfully boot and remain stable.
@ 8gb ram, I tried increasing the NB voltages up one and two clicks up. I am not sure how much voltage would be enough or too much in this case since MSI shows how much I increased in voltage, rather than actual voltage.
Point 3: Standard PC-6400 DDR2 RAM is designed to run at 1.85v. Performance RAM, which can either be PC-6400 RAM with tighter timings, or RAM designed to run faster than PC-6400 / 800mhz, may require a higher default voltage in order to boot and maintain stability. Be sure to set your RAM voltage manually to your manufacturer's spec.
Question 2: What are your BIOS settings for RAM? Please list voltages and timings.
I inserted one stick in dimm 1, booted to bios, and set the voltage to the manufacturer's 2.2v.
Timings were set to 4-4-4-12 @ 800MHz.
I then inserted all 4 sticks and resulted in same “System on, Black screen no video signal”
All four ram sticks are 100% functional.
Question 3: What tool are you using to determine whether or not your RAM is running in dual channel mode? If possible, please post a screenshot of the information and/or benchmark.
The Bios screen post shows the total ram and the screen posts stating for example “(Single Channel Mode).”
All ram modules tried so far have individually passed MEMTEST86's testing.
It may be that your board is defective, but before you look towards an RMA, it's important that you verify the basics.
I already had the first board replaced via RMA, this board has no current defects. All other parts have been verified and are 100% functional as well. I know the problem is in the Bios settings but MSI's limited manual and personnel information on the board has not helped.
MSI P7N DIAMOND
Intel Core 2 Quad Q6600 G0 ES @ 2.4MHz Stock Voltages
ASUS 8800GT 1GB ram
8GB Crucial Ballistix 800MHz @ 4-4-4-12 800MHz 2.2v (all sticks functional)
Maxtor 160GB SATAII
KingWin ABT-1000MA1S ATX 1000W
64Vista Ultimate
