Moddeb 601 Bios with TLB-Field
Polygon from RebelsHaven was so kind to mod the 601 Bios in a way that the Lan-Boot field can be used to disable the fix (enabled the tlb).
I modded the 601 BIOS for the M3A board to disable the TBL-Fix when the LAN Boot is enabled in the BIOS...
The BIOS is untested and you must be able to recover from a Bad Flash before trying this BIOS. I don't know if the BIOS is corrupt or not. I have done some other AMI BIOS this way, but mainly I Mod Award BIOS and I'm just not sure of this one.
I did not yet test it, cuz i'm running few stability test's with phenom on the m2a-vm atm.
In case you want to try it I uploaded the bios to rapidshare here.
