They're working on it today. Was a mistake in the dbase...max digits was set to 5 lol.
Love the nature and those lobbies. :p:
You are getting close Vince :toast: almost there.....amazing work:)
Less than 900 left, I'm sure you can do it.
Come on king, you got this...
use a P35.
they are faster speed for speed then 975 boards, and the ability to tweak the chipset latency with Memset33 Beta2 should definatly push you over the mark.
+ they just OC better on ram and FSB.
damit nice scores,
really amazing 3dclk with the conroe, and the ultra cards
i hope u will break 100k today
nice nice nice vince :p: .
Good job
Please k|ngp|n what's Vcore at 5400Mhz??
P35 oc well ram...ecc..ecc....but now as it is the feeding section to p5k....p5k dlx....ecc? the p5w64 is very hard main;)
Jebus :shocked:
Apparently I have been fooling myself thinking one day I might actually catch up :D
Guys Vince knows his board options. ;)
Mark seeing hipro and kp at it must make everyone in the game feel that way. :p:
99k single card wow
Very impressive Vince! :)
Looks like they fixed the ORB problem. Awesome job on your benches. :clap:
yep...working on getting around an ovp issue I encounter on my mobo, or else would be benching it for single card 01. 100k for sure with that mobo.
975x can do it too though.
Just in time for some ULTRA SLI stompage in 01' :D
Easy run at 5210mhz:
http://www.overclockingpin.com/104481.gif
ORB COMPARE
Hehe, I knew it'd be no problem for you. Now, about those last 159 points...
Man you make it looks easy 1.5K more than your old world record with lower CPU clock :shocked: :shocked: :shocked: ,,,,,,,,,,,,, Congrats :clap: :clap: :clap:
Any updates king?
First test with MSI NX8800 Ultra SLI, Asus Striker Extreme and QX6700.
http://plaza.fi/s/f/editor/images/0627ultrat.jpg
http://plaza.fi/s/f/editor/attachmen...rk06_20416.png
Ultras 700/1200 MHz with stock cooling and QX6700 @ 4020 MHz with Vapochill LS. I'll get new (and hopefully better) QX6700 soon and will try to make it to FM HoF top 5.
Raising the PCI Express buses (up to 130 MHz) or running memory higher at unlinked mode (800 MHz vs 914 MHz 3-3-3-8 1T) doesn't seem to help with the end result at all.
New week 48 QX6700 under Vapochill LS. This seems to like much more of voltage:
http://plaza.fi/s/f/editor/attachmen...rk06_20714.png
Next week I'll try with DI.
nice kingpin över 100k single--
*edit* aaa a closerlook shows that it was SLI :D
It really is too bad some jackass decided to hold his board hostage and use it for the "other team."
:wasntme:
Ha, ha, ha....You are crazy Vince....:D
