If that's the case, just compile with -O3 in Linux to get the same parts in-lined and, as much as possible for your CPU type, register passed. You'll have the best of both worlds.
No optimised clients for this little black duck. That's a road fraught with half credit and bombed work units.
Skulltrail @ 4.2Ghz 420x10
Seems off from the other results.
Vista Ultimate 64
Charles why dont you suspend all activity. Under Activity click on Suspend and Network activity suspended. Then when all the work units are done downloading rebench. I bet your scores will be much higher:)
@njkid32 : how can i have a sig like yours ?
What I did was create the widget then take a screen shot of it. I then hosted it on my ftp and made the pic a link to the wcg join page. If that makes any sense at all:D
so do you have to keep updating the screen shot we see everyday?
Naa, I'll just update it every so often. Honestly, at this point in my life the points dont mean as much as the project does to me. I just hope people actually click it and join:up:
cool... thanks... :D
Intel Core 2 Quad Q6700 2666MHz 1.275v VID @ 3500 (350x10) MHz 1.4125v
2 1GB of Crucial Ballistix DDR2-1066 5-5-5-15 @ DDR2-1050 5-5-5-15 2.1v
Gigabyte P35-DQ6 rev 1.0 F7e 2:3
EVGA nVIDIA GeForce 8800GTS G80 640mb @ stock
Windows XP Professional SP2
Silverstone 700 watt molex power supply
Swiftech MCR-320 triple 120mm radiator
Swiftech MCP-655 pump
D-Tek Fuzion CPU water block
EK FC-8800 full cover GPU water block
Masterkleer 1/2" tubing
Razer Tarantula keyboard
Logitech G5 mouse
Samsung SyncMaster 17" 712n 1280x1024 @ 60Hz monitor
Cooler Master Stacker 810 case
WCG 24/7 for XS.Quote:
Originally Posted by BOINC
2/17/2008 10:37:31 PM||Running CPU benchmarks
2/17/2008 10:37:32 PM||Suspending computation - running CPU benchmarks
2/17/2008 10:38:03 PM||Benchmark results:
2/17/2008 10:38:03 PM|| Number of CPUs: 2
2/17/2008 10:38:03 PM|| 3126 floating point MIPS (Whetstone) per CPU
2/17/2008 10:38:03 PM|| 7021 integer MIPS (Dhrystone) per CPU
2/17/2008 10:38:04 PM||Resuming computation
2/19/2008 1:36:38 AM|| 3145 floating point MIPS (Whetstone) per CPU
2/19/2008 1:36:38 AM|| 7181 integer MIPS (Dhrystone) per CPU
4400@320x10
2GBHK@480,4-4-4-12
This is why I dislike BOINC. Checked this sys this morning to see the following:
WinXP64
BOINC v5.10.39 x86_64
E4300 @ 2.4ghz
Specs in sig
2/19/2008 1:19:35 PM||Running CPU benchmarks
2/19/2008 1:19:36 PM||Suspending computation - running CPU benchmarks
2/19/2008 1:20:06 PM||Benchmark results:
2/19/2008 1:20:06 PM|| Number of CPUs: 4
2/19/2008 1:20:06 PM|| 3361 floating point MIPS (Whetstone) per CPU
2/19/2008 1:20:06 PM|| 7307 integer MIPS (Dhrystone) per CPU
2/19/2008 1:20:07 PM||Resuming computation
Edit: Vista 32 Premium
How did you copy that? I can't get it out there, not with ctrl + C either...
3384 FPU, 10801 Integer. BOINC 5.10.30 with XP x64 kickin' some serious ass :D
Q6600@3,5Ghz (not for much longer though...)
@Paladin: Don't use betas and you don't get messed up scores ;)
Q6600 @ 3.6
2x 2GB of G.Skill PQ
Vista x64
BOINC 5.10.45
3432 Whetstone
10497 Dhrystone :cool:
And thats with mems at 1000 5-7-7-19 :shocked: just set timings to "auto in bios"
GenuineIntel
Intel(R) Core(TM)2 Duo CPU E6850 @ 3.00GHz (@ 4.36 Ghz) [x86 Family 6 Model 15 Stepping 11] Microsoft Windows Vista
Professional Edition, (06.00.6000.00)
16/03/2008 11:57:57 a.m.|| Number of CPUs: 2
16/03/2008 11:57:57 a.m.|| 4224 floating point MIPS (Whetstone) per CPU
16/03/2008 11:57:57 a.m.|| 9395 integer MIPS (Dhrystone) per CPU
16/03/2008 0:18:09||Running CPU benchmarks
16/03/2008 0:18:09||Suspending computation - running CPU benchmarks
16/03/2008 0:18:40||Benchmark results:
16/03/2008 0:18:40|| Number of CPUs: 8
16/03/2008 0:18:40|| 2865 floating point MIPS (Whetstone) per CPU
16/03/2008 0:18:40|| 9091 integer MIPS (Dhrystone) per CPU
16/03/2008 0:18:41||Resuming computation
