core 2 duo e6420 2.9 not serious oc to ram
11251
Core 2 Duo E6600 @ 3.60Ghz
http://img124.imagevenue.com/loc928/..._122_928lo.jpg
I'm a noob but I gave it a try... please don't laugh :)
http://i34.photobucket.com/albums/d1...mi/results.jpg
A small change in score
Wow cool. I'll have to check this benchmark out when I get home and get my g0 Q6600 installed :)
http://img184.imageshack.us/img184/2...clearuswa1.png
Done with specs in sig. :)
Done with BSEL modded e4400 :)
http://img178.imageshack.us/img178/996/scorewy3.png
Shot at 2007-08-03
Sorry, laggy internet
Some more SC weaksauce...
Pretty much the limits of my air cooled setup.
http://img.photobucket.com/albums/v3...8NuclearMC.jpg
I cant download 2.0.0.0 build..so i give my result at 1.0.0.Final version!
http://img64.imageshack.us/img64/7195/8kfh0.jpg
Box cooling!
He is banned, he might not update with your results.
Updated for the new system build(sorry for the quality, accidentally saved as 16 color bitmap):
I'm back :up:
Thread update in roughly 1 hour :)
Should be good for top 20 of dual cores... nothing spec though for e66
volts are insane.. was just testing what it could take... thought id nuclear aswell... its from a while back.
http://img440.imageshack.us/img440/6485/nuclearfv6.jpg
Its grate:)I will post some results..
Update:
http://img170.imageshack.us/img170/9...ltimarkym0.jpg
http://img355.imageshack.us/img355/3...cordwo6.th.jpg
6520 w/ Celeron 440 I believe that's SC record for now. I'll get a better score in a bit, need to tweak mem & voltages.
Got a little better:
http://img355.imageshack.us/img355/6...cordng6.th.jpg
I recently did a clock per clock test between San Diego 3700+ and Conroe E6600, and I included this benchmark in my test. I have to say, it really uses multi-cores, which i find extremely pleasing. Below you can find my results from that test:
San Diego 3700+ @ 2750Mhz
2Gb Kingmax DDR400 @ 200 2,5-3-3-7 2T
Asus A8N-Sli
score: 4733
Conroe E6600 @ 2754Mhz
2Gb Mushkin XP6400 @ 460Mhz 5-5-5-15 2T
Dfi Infinity P-965 S
score: 8746
Here is my result with quad.
QX6800 G0 @ 4.7GHz
Attachment 62957
