Originally Posted by Leeghoofd
Vcore Voltage: 1.4 set in 1002 bios set to 1.45
Memory Voltage: 2.300v lower to 2.175
1.2v HT Voltage: 1.3v up to 1.4
NB Core Voltage: 1.4v up to 1.45
SB Core Voltage: 1.55v
CPU VTT Voltage: 1.4v
DDRII Controller Ref Voltage: AUTO
DDRII Channel A Ref Voltage: AUTO
DDRII Channel B Ref Voltage: AUTO
set it straight to 1600FSB, unlinked mode set ram 1066 manually, disable EPP profile and linkboost 2 plz, I assume you have an E6600
I also would test both ram dimms seperately with eg memtest. Thios board slightly overvolts the ram and at 1066mhz only 2.2 volts is required for these OCZ dimms (I have the same) so set to 2.1750 to get 2.2 volts. Also therea re some holes that don't work, so 1600 (400FSB works like a charm) , if you encounter a hole plz add 20mhz or so to the FSB eg 1333 should work also...
