I'll post some photos of it as soon as it "takes" a "form"....:)
I've changed the plans a bit......I'll use DDR Maximizers for each output so I'll use 3 of them for 12V, 5V, and 3.3V......The 5VSTB and the -12V will be on their own....:)
I'm realy dissapointed to be honest from the PSUs out there......:(
Running a SINGLE 8800GTX at 1.76VCore and 918MHz core/1215MHz rams with my moded (12.9V) 550Watts total (and 650Watts max) Enermax, idle goes up to 12.75V and under load it goes down to 11.48Volts......:(
Running it from my Zippy 700Watts WITH the rig, the 12V is moded at 13Volts and it goes down to 12.45Volts.......This Zippy is the one with the single 12V line......It feeds the whole rig AND the high clocked VGA as well and it still "stays" at 12.45Volts........:)
