thanks for the infoQuote:
Originally Posted by malficarHere's what I would do; make a base OC in the BIOS that has enough voltage for your higher performance ram then save. Perhaps start @ 3.0 GHz. Under windows use the Intel desktop control center to ramp up your OC. Use memset for fine tuning ram settings not available under the control center.
I have purposefully locked up my system a few times with the control center then forced a reset to see how the board behaves. It will beep a few times and not post. Turning off the psu for about 10 secs restores my last BIOS save when I power back up and boot. So everytime you screw up you would just end up @ 3.0GHz or whatever that base OC is that you decide on. I have found that way is far less painful than popping the side off the case, playing with the jumper, and having to pull a stick of my ram due to the voltage dropping to 1.84v.
You can also set three different OCs via the control center you can call up @ a touch of one button. For example; you could jump to 3.0GHz, 3.4GHz or 3.6GHz on a single tap of a preset number.
The desktop control center that will work with the BX2 is version 2.2 and you need the latest BIOS:
http://www.intel.com/design/motherbd...c/download.htm
A detail of it:
http://www.intel.com/design/motherbd.../dcc/index.htm
Latest BIOS and drivers. Select your OS and go:
http://downloadfinder.intel.com/scri...ProductID=2578
This is a very stable mobo and I am starting to like it a lot. My DVD drives behave the best on the BX2 over any other mobo I have tried for whatever the reason. On some mobos they would be very erratic, taking forever to spin up and often spinning down to stop when they should not.
I'm thinking of replacing my D975XBX with this new one
