Originally Posted by shimmishim
No, I'm not on stock NB cooling. I've switched to a swiftech mx159-cu and i do have a fan blowing over the nb and ram areas.
I've pretty much tried everything possible with this board.
I'll have to be satisfied with the fact taht i can dual superpi 32M and small fft for 19 hours.
i'm not going to get rid of the aw9d quite yet as hipro has just told us that abit is releasing a bios soon with the 1333 strap enabled or selectable through the bios.
if you check out the aw9d thread, you'll see that again no one minus 2 people can run blend above 400+ mhz fsb.
the strange thing is if you are under 400 and use something like 4:5, your mem will run fine... it's just 1:1 400+ where you start running into issues with orthos blend.
