I still have no trimmer here, but tried different resistors...
That is absolutely OK. What do you think you need the trimmers for? The max. values are chosen not to change the original voltage. Trimming the resistance down will give you higher voltage. I only said 1 MOhm because I wanted the original circuit to be rather uninfluenced.
Tried now 1 MOhm + 100 kOhm (in serie) and saw following: vPll decrease at less then 100 kOhm...
Maybe we have an error in our thoughts...
We put negative potential to positiv, which should cause decrease, we have to put positive potential to vPll to increase...;)
Maybe we should discuss this via ICQ...
Did you got my message at ICQ?
I'm wondering about this:
At resistor directly 51 Ohm, to D23 on both ends 58 kOhm...:shrug:
Ah, to ground 96 Ohm before and 146 Ohm after...
http://oc-x.de/mods/P5B-Dlx-D23.jpg
Sad, but true...
Looks like, my Dlx is dead...:(
So can't continue...
What happened?
Tried board with E8500 under LN2, just turned off and is not willing to start...
Did it work before, or was it probably already dead after your first modding attempts?
