sent u a pm tia :toast: :banana:Quote:
sent
ty very much :D :toast:Quote:
This Bios really help the Memory. I had problem going higher than 810Mhz. Now 870Mhz is stable (no memtest error) Higher, I still have error.
Still, it does help. And 1:1 is finally stable up to 870Mhz too (FSB 435Mhz). I'm sure with some more Vdimm I could go for 950.. maybe next bios..
new P5B WR = 562.99MHz
http://xtremesystems.org/forums/showthread.php?t=115446
Hi, I'm new in this forum, so cheers :toast:
I'm using Asus P5B (Not Deluxe), Allendale E6300, 2 GB of Corsair XMS2 800MHz, 5-5-5-12, 500W ULTRA V-Series PSU, BIOS 509. I have some questions:
1. What does Vanilla mean?
2. How can I change the multi to *8 ?
3. How the :banana: I can run my PC at ~400*8 :slobber: :slobber: :slobber:
Now I'm at 390*7=2728MHz. SuperPI 1MB 20seconds. When I try to set 400 the system frezes in Windows, any ideas?
Help yould be appreciated.
P.S. Sorry for my english skills. I live in Canada just 1 month :woot:
asus p5b vanilla
0309 bios
vdimm=2.1
vfsb=1.45
vcore=1.45
http://img181.imageshack.us/img181/6...i1mbla7.th.gif
can't get past 497 FSB...no boot no matter what i do...:(
vdimm mod is on the way...i think my crucial balistix pc6400 can't do ddr1000@5-6-6-15@2.1V - need more juice...
freezer 7 pro & mbo stock cooling
Does it help overclocking if i change the FSB Termination Voltage?
congrats m8 , what did u use to clock in windows ?Quote:
Originally Posted by TaPaKaH
pm me the modded bios and the vmch mod :)
finally got the big sister of this mobo.. dlx wifi :D
boo
Originally Posted by masni
Tried roughly these settings on my P5B (Vanilla) and my E6600 is idling at 50C even with a Scythe Infinity.
I have seen some able to overclock (I think a E6400) using stock voltage by about 40% but I can't easily replicate that.
My current stable speed is 360FSB using x9 multiplier but didn't try torture test it yet so it may not be stable in the end..
So my question, is the E6600 a very bad overclocker ?
Or is E6600 + P5B a bad combination ?
My setup is :
Zalman 460W
P5B Vanilla with 509 bios
2x1GB Crucial PC6400
X1900XT 512mb
Audigy ZS
2 Seagate SATA drives
2 ATA drives
AFAIK this setup is fairly standard and my PSU should handle all that pretty easily..
any one a oc tool for windows yet !
I have a P5B (vanilla) and E6400. I'm able to run 400x8 stable (orthos 19hr screen shot below). What I'm finding hard is to get long term orthos stability much over 400fsb, even if I relax ram timings / up voltage etc. I can run a single SuperPI fine, but Orthos isn't coming to the party (i.e. not stable). I will keep reading your site / info for tips. All in all pretty happy with this board.
http://img243.imageshack.us/img243/7...19hrsy2.th.jpg
I OC my Allendale E6300 to 3.2GHz :toast:
Specs:
Asus P5B Vanilla
2x 1GB Corsair XMS2 800MHz 5-5-5-15 @940MHz 5-6-6-18.
eVGA 7900GT
Cooler Master Hyper 48
Seagate 250GB
Vcore:1.39V
Ram Vdimm: 2.1V
FSB Termination Voltage 1.45V
Can't run them at 5-5-5-12 no POST :slap:
SuperPI: 17.9 sec :banana:
Anyone know ram vdimm mods?
http://img82.imageshack.us/img82/9484/32stableal8.jpg
http://img82.imageshack.us/img82/5490/untitledux6.jpg
any suggestions for a active cooler on NB/SB?
Im using a swiftech MCX159 on NB. you can also just put a 40mm fan over the NB. SB doesn't need it really.Quote:
Originally Posted by 187(V)URD@
somebody know`s if the double reboot / shut down after saving bios boot problem is fixed on restart / cold boot when overclocking on the p5b vanilla ? ( the board shuts down / restarts the power twice when you change an important bios setting . Fans and hd`s stops spinning abrupt... )
http://homepage.ntlworld.com/ad.leac...andwidth_a.jpg
or does this board boots good if the strap is over 401 mhz see the http://www.bleedinedge.com/forum/showthread.php?t=23803 story ?
Would you know what revision of your E6600 ?Quote:
Originally Posted by Pjoeloe
I'd like to know if it's a non ES and which week it was made, mine in non ES and week 25 and I have hard times overclocking it over 3.0ghz, pushing the cpu voltage seems to be the only way forward but then temperature shots up at 55 idle and above 60 under load which means nearly instead crash then.
And that's with a Scythe Infinity.
I purchased some Arctic Silver 5 and will use it tonight to see if it helps bringing the temperature down (I'm using AS3 at the moment but it may not be well applied and/or heatsink is not properly fixed either).
Dan
pushed cpu and bord i think to the max for now .
http://i3.photobucket.com/albums/y90...r/11sec969.jpg
bord is death i think :( , got me a new one tomorow and a X6800 .
next week a X1950XTX will land :D
Hi Dan, I don`t understand your reply since you quoted me....Quote:
Originally Posted by daneel3001
Nice speed :)Quote:
Originally Posted by blind_ripper
Mmh I think I quoted the wrong person indeed..Quote:
blind_ripper: what motherboard have you got ??
I am in no way able to push my E6600 at that freq with standard voltage..
Would you know which revision (week) is it ?
What is your ram ? I've got Crucial Ballistix Pc6400 supposed to go near 450mhz but I can't push that yet..
Cheers
Dan
lolQuote:
P5B vmodded
voltage on cpu is like 1.7vcore , cpu is a week 24 first batch . coold by a mach2 :D , today dice on a X6800
I see..I was surprised with the screenshot you posted showing voltage of circa 1.2v..Had a look at that Mach 2 and it's not something for me indeed :eek:Quote:
Set it to the max availableQuote:
Originally Posted by NoRogeR
