thx :) switch panel under construction.
there overall view of rig :rolleyes:
http://img230.imageshack.us/img230/7662/dsc2908hf.jpg
GX-Badangel@ Have you had any problems with you're sunbeam fancontroller what so ever?? Are you useing it on fans with leds on them.. Just useing it for the fans..
I have one just like it, but two of my outputs are dead and if i adjust the speed down once the leds start to blink.. Have to contact sunbeamtech about it, but i havent gottn to it yet
My second attempt at building a liquid cooled PC.
Built using the Corsair Obsidian 800D Full ATX Case.
Loop 01 (Blue)
- Tubing PrimoFlex Pro LRT UV Blue Tubing -3/8in. ID X 5/8in. OD (10ft)
- Coolant PrimoChill ICE Non-Conductive Water Cooling Coolant (32 oz.) - UV Blue
- Reservoir XSPC 5.25" Black Reservoir Bay w/ Blue LED
- Pump Swiftech MCP350 12 VDC Pump
- Radiator HardWare Labs GTX240
- CPU Block Swiftech GTZ
- MoBo Block EK-EVGA X58 Classified Full Board Waterblock
- Fittings Bitspower Compression Fitting-ID 3/8" OD 5/8" (x2)
- Fittings Bitspower Barb Fitting-ID 3/8" (x2)
- Fittings Bitspower G1/4 Dual Rotary 45-Degree Compression Fitting-ID 3/8" OD 5/8" (x4)
- Misc Parts Bitspower Acrylic T-Block, Bitspower Temp Sensor, Bitspower Male to Male G 1/4 Fitting
- Fans Cooler Master R4 120mm Blue LED Fan R4-L2R-20AC-GP (x3)
Loop 02 (Green)
- Tubing PrimoFlex Pro LRT UV Green Tubing -3/8in. ID X 5/8in. OD (10ft)
- Coolant PrimoChill ICE Non-Conductive Water Cooling Coolant (32 oz.) - UV Green
- Reservoir XSPC 5.25" Black Reservoir Bay w/ Green LED
- Radiator HardWare Labs X-Flow Extreme III
- GPU Block Thermaltake NG-4 (Will update the GPU blocks once the new 300 series cards arrive)
- Fittings Bitspower Compression Fitting-ID 3/8" OD 5/8" (x4)
- Fittings Bitspower G1/4 Dual Rotary 45-Degree Compression Fitting-ID 3/8" OD 5/8" (x2)
- Fans Cooler Master R4 120mm Blue LED Fan R4-L2R-20AC-GP (x2)
http://farm4.static.flickr.com/3494/...17aefc0f_b.jpg
http://farm3.static.flickr.com/2645/...52f616c7_b.jpg
http://farm3.static.flickr.com/2517/...63e124d5_b.jpg
http://farm4.static.flickr.com/3460/...4bacc3c6_b.jpg
Check out the Build Log here:
Build Log - Turambar: Corsair Obsidian 800D Liquid Cooled Dual Loop System :D
Still almost no lights, although it's working several months already. Not the first version though. Hardware changed during that time, too :)
Here's the setup 24/7:
MB: Asus M3A78-T - pretty old one, but was one of the few options on our market when I bought it.
CPU: AMD Phenom II 940 @ 3893MHz (0852BPAW)
RAM: 2x2GB OCZ Blade LV DDR2 @ 1222MHz
VC: Asus HD4890 ref @ 1050/4800
Case: CoolerMaster HAF932
PSU: CoolerMaster M700
WaterCooling:
CPU: D-Tek FuZion v2
NB: Swiftech MCW30
VC: EK-FC4890 LT
Rad: ThermoChill PA120.3
Pump: Swiftech MCP655
Reservoir: XSPC Bay
Tubing: Masterkleer 7/16" ID 5/8" OD
Coolant: Feser One Red UV
Some sleeving and other minor things.
http://img29.imageshack.us/img29/492/93415414.png http://img42.imageshack.us/img42/7986/img2395x.jpg
http://img340.imageshack.us/img340/3479/img2399.jpg
And one very old case next to the HAF..lookin' so silly :D
http://img402.imageshack.us/img402/6176/img2366t.jpg
so far this is wat i got.. my 2nd setup... still working on it
http://i37.tinypic.com/35l5m9w.jpg
"Cool" 1990 boom box mod
i7 965
Foxconn Bloodrage MB
6GB Crucial Ballstix
2 * EVGA 280 GTX SLI
DANGER DEN watercooling
X-Fi Pro SC with 750 Gigaworks Speakers
28" Hanns
300GB velociraptor
1.5 Tb storage
Tagan BZ Power supply
http://farm3.static.flickr.com/2510/...cc2fc12c_b.jpg
http://farm4.static.flickr.com/3425/...32aa97e9_b.jpg
http://farm4.static.flickr.com/3468/...52b58c96_b.jpg
you tube
http://www.youtube.com/watch?v=UHc444j-nIA
Link to work log
http://www.modders-inc.com/modules.p...ewtopic&t=3805
Link to coolermasterCase modcontest
http://www.coolermaster-usa.com/micr...st09/index.php
That is the most awesome thing i have ever seen! i want!
Welcome aboard jjsky5000 that is an awesome build; how you got all that in there is an amazing feat.
jjsky5000 you scared the hell out of me. I thought the 80's was coming back to haunt me with my old ghetto blaster! :rofl: Awesome job btw!
Well it was very hard. I about quit three times. i am glad i kept going. I am now cleaning the cuts it up abit with some UV trimming. I wanted to use my 1/2 green but i could get teh loops small enough to bend nicly so i went with 3/8. It is cool and powerful what more can you ask for.
full work log here on how it was all put in.
http://forum.coolermaster.com/viewtopic.php?f=9&t=13627
:welcome: jjsky5000! :D
That's one hell of a work, man! :up:
@ jjsky5000 - Man that is one of the flat out coolest and most inventive projects I have ever seen. I'll admit that at first I only saw the top picture you had posted, and I wasn't quite sure what I was looking at. After I saw the other two, I just had to go look at your worklog for it. The scope of vision and creativity here are absolutely amazing. To not only turn the boombox into a mod for a water cooled rig, but to also allow the original shape and visual scheme of the boombox to be held, while enhancing it in subtle and creative ways, AND having the system be effective, I'm just at a loss for how you came up with this. Well done! :clap::clap::clap::clap::clap:
wOw VERY NICE IDEA jj great work there :clap:
jjsky5000, great retro mod! :D
Respect dude, that's SO flucking beautiful! :eek2:
wow jjsky great job man :up:
Updated added link to worklog & video
Thanks. You should see the work log. I wasnt sure how I was going to fit it all in!!!! I kept testing pieces before i put them in (lol)
here my both x58 setup
http://i34.tinypic.com/23uzoya.jpg
New pics, now with uv green aditive:
http://img.photobucket.com/albums/v2...u/IMG_3514.jpg
http://img.photobucket.com/albums/v2...u/IMG_3515.jpg
http://img.photobucket.com/albums/v2...u/IMG_3522.jpg
http://img.photobucket.com/albums/v2...u/IMG_3526.jpg
cpu: i7-920 d0 w/ t56 v3 @ 4ghz
mb: ex58-extreme
ram: kingmax elpida 3x2 w/ nexus hxr-5500 @ 1600mhz
vga: gtx-285 w/ ek wb
psu: hx620
http://pc-style.hu/word/wp-content/u...9/09/br4d3.jpg
http://pc-style.hu/word/wp-content/u...9/09/br4d6.jpg
http://pc-style.hu/word/wp-content/u.../09/br4d12.jpg
for other pics click here.
cheerz!
oh, i forget... here's a fast shot w/ flash:
http://img19.imageshack.us/img19/4849/br4dvaku.png
Nice job Pisti :up:
thank you szik. :rolleyes:
@ Jay78 -- love your color scheme! Nice clean tubing routing, br4d.
And, while I hate to nag ... please remember that only 4 pics are allowed in this section. If you'd like to show more, then please include a link to another gallery or include thumbnails. Thanks!
oh, i'm sorry. i modified my post, there's only 4 pics now.
Thanks, br4d! Just trying to keep things tidy ;) That's a very nice gallery you linked to!
I'll also make a note here to encourage people to post their work logs as well. It's good to have a broad range of projects in the work log section, so people shouldn't hesitate to do a work log because they think their project isn't complicated. It's also a good place to get feedback and suggestions, and you can include many more pics! OK ... public service announcement over ... back on topic!
Yes, yes Malik, nobody has forgotten your incredible workmanship haha.
BTW, when are you going to get that awesome RAM block on? Did you get it yet?
br4d! Nice HAF! It reminds me that I need to take pictures of mine! I still haven't... :/
thanks wezly!
i want to put my mo-ra 2 to the right side panel soon, and if it's ready, i make new pictures.
Every time I see things hanging off the sides I cringe. I hate doing it off the back with my current HAF config and I am dreading doing it to my Raven RV-01, but I may have to.... Oh well, maybe I'll just suck it up and build a rad cage and.... yeah..... gears are turning hahaha.
Good luck with that!
i7-920 20x200 1.35000v bios voltage, idle: 38c, load: 70c (linx)
gtx 285 750/1550/2700, idle: 34c, load: 45c (furmark)
my cpu block's not so good, but i like the core's temps. :up:
um yep, he's right lol.
a very nice picture plastek!! :D
pardon my ghetto studio, i'm not a professional photographer, photos taken with flash :D
Phenom Monsta
http://img522.imageshack.us/img522/3735/mg3766.jpg
http://img522.imageshack.us/img522/8051/mg3834.jpg
http://img397.imageshack.us/img397/6317/mg3844.jpg
http://img185.imageshack.us/img185/2548/mg3773.jpg
Loving the monsta, ridney. That's one of the few radiators I've seen that actually looks good outside the case - and it goes well with the size case you used. Nice shots.
Ridney, you may not be a professional photographer but the rig looks pretty damn pro for sure. Great work man! If I may how did you attach the Rad to the back of the case like that?
Thanks guys. Detale, i only used 4 x M5 50mm length bolts to mount the rad :)
Yes it looks good... I feel for the fan that's holding up all that weight....
i'm glad that it turned out positively. at first, i was hesitant with my rad choice basing from all the monsta love that i have been reading here, but in the end i made the right choice. i really love it.
thank you all for the nice compliments, especially from you guys who are exceptional modders, i'm greatly honored :D
hi
little udapte :D of my obsidian
http://lh3.ggpht.com/_hObt9MK11bI/St...6/DSCF0094.JPG
http://lh6.ggpht.com/_hObt9MK11bI/St...6/DSCF0099.JPG
http://lh3.ggpht.com/_hObt9MK11bI/St...s/DSCF0112.JPG
http://lh3.ggpht.com/_hObt9MK11bI/St...U/DSCF0115.JPG
http://lh5.ggpht.com/_hObt9MK11bI/St...o/DSCF0093.JPG
Nice work BlackHouse! :up:
Nice build Blackhouse great photos too.
Great work. Very clean build :clap:
very nice man, looks awesome as hell lol
I really like the black and white builds, they're definitely my favorite. That being said, any internal shots Blah? :)
Omg. This is very beautiful:rolleyes: Can we see some inner pictrues?
nice job knet! :up:
Thx :)
It isnt finish, but i have some old pics.
http://www.abload.de/img/p1000397raou.jpg
http://www.abload.de/img/p1000401ovpt.jpg
http://www.abload.de/img/p100029779h3.jpg
Well here are some better pics. there not that great! I don't know how you guys take such nice pics. I just got this new DSLR and it looks like my phone pics. LOL!
Attachment 98015
Attachment 98016
Attachment 98017
Attachment 98018
E6750@3.2Ghz - 6GB PC6400 - 7900GT - ~1,64TB - Stacker STC - 01 - Neo He 550 ...
Laing DDC1TB 18W - XSPC RS120 - XSPC DDC Restop - D-Tek Fuzion V2 - Bitspower ...
Latest revision of my stacker
http://i33.tinypic.com/2i7pl.jpg
Recently made some cuts to the Thermaltake Armor (enlarged the holes in the top plastic piece, made holes for the cpu backplate, mobo 6pin power connector, 24pin power connector, and gpu pci-e cables, and enlarged the 4 vertical holes at the side of the front bays so molex connectors could fit through them) and painted the whole thing black.
http://cypher.adrenzone.net/case-cuts.jpg
http://cypher.adrenzone.net/case-finished2.jpg
http://cypher.adrenzone.net/case-finished.jpg
Components;
»HAF 922
»CPU: Intel Core i7 940 OC'd to 3.69
»Motherboard: Evga X58
»EVGA GeForce GTX 295
»CORSAIR DOMINATOR 6GB (3x2GB)
Water cool parts;
»RAD - XSPC RS360 & XSPC RS120
»CPU Block - Alphacool H14 Yellowstone BRB
»Koolance Northbridge/Southbridge Water Block
»Black Feeser Mosfet Block
»EK-Multioption RES 150
»Swiftech MCP655™ Series 12 VDC Water Pump
»Koolance-D5 X-TOP
http://img94.imageshack.us/img94/6321/dsc01605.jpg
http://img26.imageshack.us/img26/7388/dsc01610qf.jpg
http://img88.imageshack.us/img88/8453/dsc01602.jpg
http://img94.imageshack.us/img94/6161/dsc01609.jpg
http://img26.imageshack.us/img26/3734/dsc01608yp.jpg
I have some lighting, LED's coming this week to lighten it up a little. I am also going to convert my side panel into a side window, might put a fan through it. Just not sure yet.
Chad
Added some more UV CCFLs.... he he, not much of an update.
http://farm4.static.flickr.com/3481/...a987d387_o.jpg
Nice Snapshot scampy :)
Yup.
Over here http://www.xtremesystems.org/Forums/...d.php?t=232913
Board: MSI 790FX-GD70
GPU: 2x Zotac 260GTX + 2x EK for 275GTX
Ram: Kingston value + Arctic RC
Cooling: Laing + BI GT360, Masterkleer 15,9/11,1 Anfi Mainboard Set
http://www.abload.de/img/img_229306hr.jpg
http://www.abload.de/img/img_229646pg.jpg
Awesome rig, great wiring.
Is that the new grand blue? I want :( makes aqua look like :banana::banana::banana::banana:
Thx and yes that is the new grand bleu mixed with classic black :D
very nice pc schlingel, i love it. this "wiring style" looking very good. congrats man!
Very beautiful rig schlingel, more pics please.
Meticulous attention to detail Schingel.......first class!
Yeah, looks nice. Will wait for full setup pics
Very nice build Schingel, got any more pics? =)
watercooling is final but the i am still working on the other hardware. more pics when it is done ;)
original driver + modded windows file:
http://forums.techpowerup.com/showth...=60844&page=80
but thats another topic ;)
This is my rig with the new 5870 cards and EK water blocks. I run 2 loops in my system and decided to use 2 different colors. Thats a 180 mm fan attached to the Antec 200mm Radiator and yes I know its aluminum before anyone starts to rant and rave about mixed metals.Been running this way for 6 months, recently took block apart and no visual damage whats so ever. I use distilled water with ptnuke.
running crysis with everything turned up to the max cards never hit 45c.
ah, omg, i love it... give it to me please.
Yeah, white tubs and cords are so awesome + white fan....
@ 1337_alpha - What coolant is that?
@ Scor12 - You have soooo nice and clean pictures!
But uhm.. i couldnt help notice that you mounted your cpu block the wrong way? Was this intentional?
