hi all!
here's my settings with this board!
http://img4.imageshack.us/img4/8731/ev9745.jpg
hi all!
new build q9550 w/ DFI X48 LT T2R , gtx260 videocard, Ballistix 800mhz, corsair tx650 ps.
on startup, led's on, fans spin, but system will auto shutdown at post code 26.
any ideas???
I had the exact same thing happen with my build recently. I ended up having to unplug my video card (major pain due to water loop), unplugged the psu, and removed the battery. I left it like this for about twenty minutes and replace it all back and it worked like a charm. Hope this helps!
POST code 26 mean video card initialing problems.
tx for the replies -- will try suggestions. :)
i have posted this before the backup came up, i will write it again. :(
my goal is to make mobo stable at 530x8 (or 8,5 if that's possible! :D ). I own an 8400 and a 2x2 kit, temgroup Xtreem, max memtest on this mobo 550 :woot: .
i managed to boot at these settings:
http://i70.photobucket.com/albums/i1...530everest.jpg
used some settings from there -> http://www.outofspecs.gr/forum/showt...?t=2252&page=2Code:CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
O.C. Fail retry Counter: 1
O.C. Fail CMOS Reload: Disabled
CPU Clock Ratio: 8x
CPU N/2 Ratio: Disabled
Target CPU Clock: 4240Mhz
CPU Clock: 530
Boot Up Clock: AUTO
CPU Clock Amplitude: 800mv
CPU Clock0 Skew: 200ps
CPU Clock1 Skew: 0ps
DRAM Speed: 333/667
- Target DRAM Speed: DDR2-667
PCIE Clock: 100mhz
CPU Spread Spectrum: Disabled
Voltage Settings
CPU VID Special Add: +325mv
DRAM Voltage Control: 2.30v
SB Core/CPU PLL Voltage: 1.51
NB Core Voltage: 1.55
CPU VTT Voltage: 1.250
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: strong
x MCH RON Offset Value:00
x MCH RTT Offset Value:00
x MCH Slew Rate Offset Value:00
x MCH VREF 1 Value:23
x MCH VREF 2 Value:23
x MCH VREF 3 Value:A3
x CPU GTL 0/2 REF Volt: 0.620X
x CPU GTL 1/3 REF Volt: 0.620X
x North Bridge GTL REF Volt: 0.67X
DRAM Timing
- Enhance Data transmitting: AUTO
- Enhance Addressing: AUTO
- T2 Dispatch: Disabled
Clock Setting Fine Delay
- DRAM CLK Driving Strength: Level 5
- DRAM DATA Driving Strength: Level 8
- Ch1 DLL Default Skew Model: Model 3
- Ch2 DLL Default Skew Model: Model 3
Fine Delay Step Degree: 5ps to 80ps
Ch1 Clock Crossing Setting: AUTO
- DIMM 1 Clock fine delay: Current 2024ps
- DIMM 2 Clock fine delay: Curren 1174ps
- DIMM 2 Control fine delay: Current 1112ps
- DIMM 1 Control fine delay: Current 1112ps
- Ch 1 Command fine delay: Current 74ps
Ch2 Clock Crossing Setting: AUTO
- DIMM 3 Clock fine delay: Current 1900ps
- DIMM 4 Clock fine delay: Current 937ps
- DIMM 4 Control fine delay: Current 886ps
- DIMM 3 Control fine delay: Current 224ps
- Ch 2 Command fine delay: Current 280ps
Ch1Ch2 CommonClock Setting: AUTO
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto
Common CMD to CS Timing: 1N/2N/AUTO (command rate)
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 15
All Precharge to Act: AUTO
REF to ACT Delay (tRFC): AUTO
Performance LVL (Read Delay) (tRD): AUTO
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
- Channel 1 Phase 0 Pull-In: AUTO
- Channel 1 Phase 1 Pull-In: AUTO
- Channel 1 Phase 2 Pull-In: AUTO
- Channel 1 Phase 3 Pull-In: AUTO
- Channel 1 Phase 4 Pull-In: AUTO
Ch2 Read delay phase (4~0)
- Channel 2 Phase 0 Pull-In: Auto
- Channel 2 Phase 1 Pull-In: Auto
- Channel 2 Phase 2 Pull-In: Auto
- Channel 2 Phase 3 Pull-In: Auto
- Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Read to Write Delay (tRDWR): AUTO
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): AUTO
ALL PRE to Refresh: AUTO
i managed to boot at my desired settings but it isn't stable.
also, i don't know how do we set the MCH VREFs and the driving strength. if there is a guide or something it would be appreciated. ;)
hey guys, good to see the forums up and running after the downtime. (Im a mod over at TPU, where the refugees hid out and created a hell of a mess in tent city)
Anyway i just got this mobo and i'm trying to sort out a dilemma.
My setup is currently just like these
http://www.exoid.com/wp-content/uplo...3/img_1141.JPG
http://www.exoid.com/wp-content/uplo...3/img_1142.JPG
Unlike that guy with his case, mine has the PSU up there and its causing me some temp issues. I need to find a northbridge cooler replacement thats going to fit, and allow me to rotate the CPU cooler so that its blowing out the back of the case again.
The two main NB coolers i think MIGHT do the job are the Thermalright HR-05 IFX, and the Xigmatek Porter N881 HDT.
I'm working my way through this thread but theres a hell of a lot of thread to read through, so if anyones found a way to get a TRUE120 to fit rotated the other way, please let me know!
Edit: i found THIS picture, but the angle makes it hard to tell if the top PCI-E slot is still usable.
edit 2: just a few pages back was this post which gives me hope. i will try PMing that user to get a pic of his setup
mussels you can install the true any way you want
i had to shve my nb heatsink as it was touchin the true
before you replace the stock nb cooling try a 120mm fan;)
i have the ifx it beats the stock+120mm fan by 2c
i even put a xigmantek 1283 on nb lol but not much temp difference:rofl:
if you was to buy 1 i think the porter is a good choice
http://www.xtremesystems.org/forums/...=174177&page=3
its a much better idea to get a new case IMO, what do u have now
I originally did it the other way around.
I gently massaged the interfering heat pipe on the TRUE about 1-2mm in. It makes no difference to the TRUE and it just clears the OE heatsink. Only one heat pipe doesnt clear when it's mounted facing IO panel. All you need is a small shifter or spanner or similar, and gently tap the pipe around the area that hits and you'll massage it clear.
http://hosting02.imagecross.com/imag...51DSCF0066.JPG
http://hosting02.imagecross.com/imag...28DSCF0064.JPG
Heres a pic with Thermalright HR-05 SLI/IFX.
Driving strength is set for the ICs. 6/8 usually works by default. To adjust you either increase clk drive/decrease dq drive or decrease clk drive/increase dq drive, but you need to change DLL models too when doing this.
On my DDR2 G.Skill 1100mhz 2x2gb sticks I've found the best combo for me is, in the format CK Drv/DQ Drv/Dll 1/Dll 2
3/8/5/5 or 4/7/6/6.
Drive strength is the amplitude the clock out and data out are driven at within the DDR delay locked loop relevant to clock in, and out for ddr mux.
MCH Vref are set with respect to the difference default.
Vref1=00h, Vref2=00h, Vref3=80h.
The represent voltage reference points at voltage crossing. You adjust them to the same ratio they are set. ie, Vref1=05h, Vref2=05h, Vref3=85h.
Unless you understand what they do stick to this. :) Also you can benefit from adjusting MCH slew rate offset, and MCH ROn/Rtt.
Ie.
MCH Rtt = 06h, MCH ROn = 03h, MCH Slew rate = 0Ah, MCH Vref1 = 18h, MCH Vref2 = 18h, MCH Vref3 = 98h
I'm pretty certain that Rtt = 1/2 ROn when setting it, since Rtt is usually 2 * ROn impedance. ie Rtt = 120 ohms, Ron = 60 ohms.
yeah i dont see why not. I don't have a need for it so I use a 80x25mm fan instead there.
i'm pretty sure it doesn't interfere with the slot, been a while since I had my PC apart though.
Hi, im about to order myself a DFI X48 LT T2R motherboard, and am wondering what size fan fits into the NorthBridge Heatsink (AKA The Heat Minator)??? is it an 80mm fan?
also how hot does it get when overclocking? im fitting in my q6600 and planning to overclock it as far as i can (with a GTZ waterblock) should i invest in a NB waterblock??
many thanks!
yah water is a mush for the x38/48, and i if u get the mcw30 its the lest restrictive and keeps the NB +2-3c of the water
if u get an antec 300 it would fix all of your problems and they cost like $60 so thats not much more than the NB cooler and some fans
hmm, well im looking for about 3.2ghtz from my q6600, im currently on 3.2 on my Abit ip35 pro XE board...which has given up the ghost now
im just putting in a new mobo so ill still be liquidcooling my q6600 and will be adding in a NB waterblock....so would you still suggest me not getting the X48 LT???
get whatever is cheaper with the x48 or p45
dont get me wrong the x48 is a good board
but its not as fast as the p35 or p45
just get whats cheaper
only reason i'm goin back to x38 soon is that i bought another 4870 to go crossfire
or my x38 be in a box for another year
i'm still itchin like crazy to buy the ut-p45:rofl:
why is it to load, it has the same sound dampening and more fans, more fans mean that u can undervolt and get the same flow for less noise and it allows the top to be used for a fan and the bottom for a psu so it will be cleaner.
its the same type of case so im just giving a suggestion since its about the same price
