wow thats a really sweet block :slobber:Quote:
Only thing i would chnage is that it has the barbs on the top as the side is going to be a right roaly ***** to fit and maybe them to be made not so restrictive. I'd love to contact this guy and ask him, send him my mobo and have the block made
Looks like that block fits in with the stock heatsink like a puzzle piece. I would be worried that the block isnt making good contact with the stock heatsinks, if that is how the block is made.
Hello new here.
This is mine :)
http://img75.imageshack.us/img75/7233/dsc02134or4.jpg
http://img395.imageshack.us/img395/2046/dsc02153ky5.jpg
http://img392.imageshack.us/img392/2750/dsc02156rd5.jpg
http://img392.imageshack.us/img392/3270/dsc02158fz6.jpg
Still needs a bit of tidying up.. especially with the PSU
Woah lol, how the heck did you go from green to orange on the gpu waterblock?
Lo0L! I guess he's just using colored tubing and not colored additive\coolant. Am i right Mister Carbine ?Quote:
Originally Posted by ramenchef
PS: I think i saw your Rig over at Guru3D :D
Updated my water-cooling... kinda stole some of Zeus's ideas. :P
http://members.cox.net/lharris151/DSCN0658.JPG
http://members.cox.net/lharris151/DSCN0660.JPG
http://members.cox.net/lharris151/DSCN0664.JPG
Originally Posted by JoeBar
Thanks Joe. :toast:
I already took that noisy thing off after i discoverd how damn noisy it was.
I'm thinking about putting an EK block on the northbridge.
The thought of taking the loop apart makes me shiver though. :D
I did put a fan over the mem/nb heatsink, cooling is sufficient atm but watercooling the nb looks better.
Really like the front, but the inside.. :p:Quote:
Originally Posted by Carbine
Two different loops for cpu and the rest i assume?
You shouldn't have your D5 pumping into your res, you will be losing performance on your systemQuote:
Originally Posted by Athenos
The Heatsinks are soldered on to the bord! On the DFI they make very good contact as alll have cooled them with a fan and touched them and they get hot.Quote:
Originally Posted by Polizei
If you look at the photos you'll see it fits very tightly. I guess you could even use some AS5 inbetwen the heatsink and block to get something extra out of it.
I just really want one for my BX2
lol... it was some of my old tubing i had lying around.. when i plumbed up the GPU loops, i didn't have any new tubing left so i had to resort to some old tubing i had lying around...but looks quite nice changing colours.
The rig consists of 3 separate loops cooling different components. CPU being blue, GPU being green/oarange and all the peripherals on orange/red
Aplus Blockbuster
Abit nf m2 nview
A64 am2 3500+
2x512 adata pc4300
Gigabyte 7600GS
Wd Se16 250Gb
Ocz Modstream 520w
Liteon dvdrw Sata
Sunbeam reobus
Laing ddc + top alphacool
Danger Den tdx nozzle 5
Black ice Micro II
http://www.atris.it/Forum/photoplog/...1_IMG_0944.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1001.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1014.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1019.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1010.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1009.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1011.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1012.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1013.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1018.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1035.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1039.jpg
http://www.atris.it/Forum/photoplog/...1_IMG_1057.jpg
Here are pics of my 1st W/Cing setup i've ever built. Had a ton of fun installing everything, and I believe the end result was worth it. This setup is just cooling the CPU, and my conroe seems to be enjoying it:) Now let me see if I can insert the pictures the right way?
23C idle! That's really good for 3,6 G. I have Tuniq Tower and I have 37-40C :(. Getting water cooling soon :).
Hmm, I don't see another way to do it... my temps are just as good now as they were when I was using a t-line...Quote:
Originally Posted by Timmay
Wasn't filling a pain in the ass? To me, it looks like the liquid would rocket out of the reservoir if you'd open it up..
Nope, didn't have any problems filling at all.
I was thinking about wc'ing the nb also when i was planing project Zeus but i've decided to go with a descent nb hsf. Haven't regret it.Quote:
Originally Posted by Zeus
As for the shivering u have about taking apart your loop, i have the cure...
Get a MM UFO! :D
His pump is good, dude. His loop is going in the opposite direction of that which you perceive. ... unless im the one whos mis-perceiving something here:confused:Quote:
He is cooling the GPU first, which is actually a logical idea seeing that it is more expensive.
No.
Hes pulling the water out of his res, through his Storm and then through his GPU block. His loop is operating under a vacuum of sorts, not positive pressure like it "should" be.
This WAS my first step into custom water cooling... dont laugh it worked good. Dosent everybody have a custom griffin radiator laying around??
http://img208.imageshack.us/img208/6573/dsc00382sl1.jpg
http://img208.imageshack.us/img208/9...ture009us4.jpg
That is not good, because the positive pressure at the discharge would probably make water flow much more than the "low pressure zone" created by the suction and letting the "normal" pressured water fill it up. Thats why a vacuum cleaner has a super powerful fan but the suction is way weaker than the power of air blowing out.Quote:
lol, that custom radiator stands are weird but kind of nice :D
serial, I was telling him that it was bad to run it like that. Its better to run it with positive pressure.Quote:
Originally Posted by serialk11r
